p-boot images
Lately have been testing PinePhone beta with convergence.
Went through all OSes on b-boot and they all work like a charm, including the dock (charger, USB, HDMI, Ethernet)
What I noticed is that all OSes on b-boot use Megi's patched 5.13-rc4 kernel.
Then the next steps for me was to install Mobian with FDE to eMMC, all went well except HDMI is not working with the dock.
I tried bullseye, bookworm, unstable up to kernel 5.13 but none of them fix the HDMI issue.
Question:
Did anyone try to install Mobian version from b-boot to eMMC with FDE enabled?
or
Is it better to install Megi's kernel and any other patches on top of standard Mobian distro build?
Seems that Megi is aware of this issue. As he just described the problem on his blog.
https://xnux.eu/log/#033
Will try the quick workaround and will report the results here.
  boot gets stuck shortly after disk decryption vortex 9 12,753 09-11-2024, 05:40 AM
Last Post: normangraves
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 11,454 11-22-2023, 11:46 AM
Last Post: aLoop100o
  How to check if tow-boot is installed? jojuma 3 5,507 09-29-2023, 11:29 PM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 2,551 09-01-2023, 11:29 AM
Last Post: Mahgue
  4G data on default startup / boot dcinoz 1 3,270 04-29-2023, 11:24 PM
Last Post: dcinoz
  PinePhone won't boot after software update jb2000 2 5,197 03-17-2023, 07:26 AM
  Boot log analyses -> GPU no regulator (mali) found freelectro 0 3,042 03-06-2023, 12:06 PM
Last Post: freelectro
  [solved] Black screen at boot time mdk 0 2,859 01-13-2023, 03:33 AM
Last Post: mdk
  No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED 3x5co 1 3,673 01-04-2023, 06:46 PM
Last Post: 3x5co
  Does tow-boot allow periodic wake from suspension to check for notifications? DrPlamsa 4 7,263 12-31-2022, 10:56 AM
Last Post: DrPlamsa
