No notifications on lock screen
(08-11-2021, 01:43 PM)ragreenburg Wrote: ... only showing apps that are mobile friendly (apparently introduced in Phosh 12) that I don't see on my phone so who knows...
See LinMob description here, especially in addendum how it is disabled completely.
@ragreenburg it appears that Mobian is still on Phosh 0.11.0. I'll take a look when I get the update.
(08-16-2021, 07:21 AM)DrPlamsa Wrote: @ragreenburg it appears that Mobian is still on Phosh 0.11.0. I'll take a look when I get the update.
I forgot I am on the =unstable#how-to-i-switch-to-mobian-unstable]unstable branch because that's the only way to get MMS working. For what it's worth unstable has been fine for me and is currently on Phosh 0.13.0.
I had bad results running unstable on a Debian system, in the long, long wait for Woody. I know that was long ago and this is different, but is it different enough that it won't break something important with every update?
Is it possible to use pins to get just a few packages from unstable, like the MMS program and Phosh 0.13.0? I think I can figure out the pins, but I'm wondering if the dependencies will stop me?
Pinephone beta edition, convergence model, Mobian Bookworm with Phosh.
I honestly have no clue if you can just pull a few packages. That being said, I have been on unstable for 6-7 weeks now and using Mobian as my daily driver and have had zero issues. I honestly forgot I was even on unstable. That being said, they are switching from Jessie to Bookworm so we won't even really be getting updates aside from security stuff.
Bullseye will be getting security updates from Debian, while a-wai and team are moving on to Bookworm,
so Bookworm will be where the new features will be "blooming".
I 'believe' that the continued nightly releases will actually be the Bookworm .... perhaps a-wai will make it a bit more clear soon.?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
*  I just got my first locked screen notification!,  August 21 nightly release.
almost everything works, the software store isn't loading atm, but great otherwise.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
  OpenTTD game - Error: no usable screen resolutions found. eugenr 3 6,430 06-23-2026, 01:12 AM
Last Post: Mary_Davis
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 1,245 12-23-2025, 04:34 AM
  On-Screen Keyboard Arrow Keys biketool 11 11,418 12-23-2025, 04:25 AM
  How to add an homemade app to the main screen? JChdeL 3 2,250 11-04-2025, 04:13 AM
Last Post: JChdeL
  New Install, apps start but don't show up on screen?! RT3 2 3,469 07-18-2025, 07:56 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,499 01-15-2025, 08:08 PM
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 6 10,539 08-05-2024, 06:12 AM
Last Post: baptx
  Screen auto-rotation sensitivity mdk 0 2,480 12-26-2023, 06:08 AM
Last Post: mdk
  Screen stay black unless power key pressed short freelectro 0 2,602 06-24-2023, 01:55 PM
Last Post: freelectro
  Unsuspend → Black screen mdk 15 18,508 06-22-2023, 11:20 AM
Last Post: Melechtna
