USB C connector loose?
Anything I plug into the USB-C connector on the phone is very easily dislodged.  I mean I barely touch the phone and it comes unplugged.  Any suggestions?  It feels like things don't plug in far enough to lock into place.  Perhaps there is a cable extender/adapter that would help?
Thanks!
(08-09-2021, 01:02 PM)bceverly Wrote: Hi,
Thanks!
Hi Bceverly,
I've also had problems with my USB-C connection. In my case the supplied cable only charges one way up... presumably this is also a symptom of a loose connection. It's workable for the time being but not ideal as if I plug it in in a hurry, or forget to check, I have a 50% chance of the phone not charging at all.
It seems to me that this component of the Pinephone could and should be physically improved.
For byte-sized tech and software tips check out my Danimations Digital Media tips channel on Youtube Big Grin
Same here. Mobian CE. I've thought from the beginning that it's another hardware design flaw.
Thanks!
I use one of these to save wear and tear on my USB-C connector  https://www.aliexpress.com/item/32849697882.html
  Battery connector dead mdk 5 5,348 01-15-2026, 02:24 PM
Last Post: mikeb
  USB-C connector Overheated and melted nickbenjones 2 5,356 05-26-2023, 06:16 PM
  GPS Antenna - external connector? GregH 14 24,584 09-09-2021, 09:24 AM
Last Post: HobanWashburn
  Fragile SIM card connector hakkou 1 3,903 08-25-2021, 07:44 AM
Last Post: wibble
  Micro-USB 3.0 connector for the PinePhone? Peter Gamma 1 4,411 03-10-2021, 10:11 AM
Last Post: wibble
  broken connector-pin for the accu alwi 2 6,182 02-23-2021, 06:28 AM
Last Post: scholbert
  Main Board Swap: Camera connector problems tyha 5 10,625 11-19-2020, 06:25 PM
Last Post: pajux
  Wobbly USB-C connector? pregier 5 11,396 10-16-2020, 10:22 AM
Last Post: wibble
  Pin missing,loose spring in phone, audio jack not working Jantje 3 8,043 06-09-2020, 02:47 PM
Last Post: wibble
Bug USB Type-C connector overmold conflicts with the back cover ngkz 1 5,226 05-10-2020, 12:19 AM
