Enter disk decryption passphrase error
I've been using my Pinephone CE running Mobian for a few months. Recently, I apparently executed a command in terminal that has caused the phone on startup to display this message that I can't dismiss because I don't know the passphrase:
Can I fix this easily? Or, should I flash and install another system on the phone?  Huh
That's what I'd expect to see if you had used the installer image to set up an encrypted root filesystem. The purpose of that is to prevent anyone who doesn't know the password from accessing any of the data. I don't know how you could accidentally trigger that from ordinary mobian, but IF you have then reinstalling will almost certainly be the only option. Someone else may have a better idea of what you might have done.
I'm going through this atm.  I've actually forgotten my disk password.
I installed the fel boot mode onto the sdcard and plugged in the usb cable and powered on.
https://linux-sunxi.org/FEL#Through_a_sp...card_image
On my computer (usb host) I run.
$> dmesg -w &
usb 1-2: new full-speed USB device number 74 using xhci_hcd
$> ./boot-tools/sunxi-tools/sunxi-fel  -l
USB device 001:074  Allwinner A64    92c089ba:24204620:78f4c71c:0c030710
$> cd boot-tools && make pinebook_ums
usb 1-2: New USB device found, idVendor=0bb4, idProduct=0fff, bcdDevice= 2.00 usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3 usb 1-2: Product: AllWinner Technology usb 1-2: Manufacturer: 20101201120001 usb 1-2: SerialNumber: USB Mass Storage usb-storage 1-2:1.0: USB Mass Storage device detected scsi host5: usb-storage 1-2:1.0 scsi 5:0:0:0: Direct-Access    USB2.0  USB Storage      0100 PQ: 0 ANSI: 2 sd 5:0:0:0: Attached scsi generic sg4 type 0 sd 5:0:0:0: [sdd] 61071360 512-byte logical blocks: (31.3 GB/29.1 GiB) sd 5:0:0:0: [sdd] Write Protect is off sd 5:0:0:0: [sdd] Mode Sense: 03 00 00 00 sd 5:0:0:0: [sdd] No Caching mode page found sd 5:0:0:0: [sdd] Assuming drive cache: write through sdd: sdd1 sdd3
Then I can try to unlock the partition using cryptdisk
$>cryptsetup isLuks /dev/sdd1 && echo $?
1
0
$>cryptsetup luksOpen /dev/sdd3 mobian
If all else fails then reinstall.
(09-05-2021, 12:57 AM)warrenc5 Wrote: I'm going through this atm.  I've actually forgotten my disk password.
I'm sure you've noticed this already but just in case...
I realised on mine that the keyboard for entering the encryption passphrase on boot differs from the keyboard in use once it's fully booted.
The most notable difference is the Shift key - it actually works like a Caps-Lock.
Once you press it, everything you type from then on will be in uppercase until you press it again.
I didn't notice on my first few attempts and was trying to work out where I'd made a mistake in my phrase!
Grr.
  OpenTTD game - Error: no usable screen resolutions found. eugenr 3 6,692 06-23-2026, 01:12 AM
Last Post: Mary_Davis
  Full disk encryption with calamares: beware of last testing upgrade! mdk 3 6,004 02-21-2025, 07:25 AM
Last Post: dragonhospital
  How to use an NVMe disk as rootfs Smaking 3 3,566 11-29-2024, 06:51 AM
Last Post: walter1950
  boot gets stuck shortly after disk decryption vortex 9 12,655 09-11-2024, 05:40 AM
Last Post: normangraves
  Chatty Matrix Decryption Key jojuma 2 3,791 02-26-2024, 12:48 PM
  [Megapixels] Flash strobe, pictures viewer and MPCamera error 22 freelectro 1 4,070 08-30-2023, 03:59 AM
Last Post: karensather
  low disk space on file system root revisited benedikt55 2 4,566 09-24-2022, 10:16 AM
Last Post: benedikt55
  Low Disk Space on Filesystem root ichbins 9 12,703 08-28-2022, 10:52 AM
Last Post: Eugo
  Error - megapixels not opening user641 17 25,356 03-29-2022, 03:43 PM
Last Post: bcnaz
  Flatpak error during apt update user641 0 2,642 02-14-2022, 08:35 AM
Last Post: user641
