Replace/Solder USB-C port on Pinephone
They very laggy USB-C port is a big issue for charging the phone (especially on a bicycle with dynamo or solar panel).
Is there any chance to solder a new port onto the phones pcb?
If yes, which parts would I need to buy?
https://www.ebay.com/sch/i.html?_from=R4...r&_sacat=0
Soldering I guess is somehow like this:
https://www.youtube.com/watch?v=e6TMxctCcxU
Any detailed walk-trough on how to open the phone and how to replace the port?
Cold I instead charge via pogo-pins with a 3d-printed custom case?
I can not understand the problem. If you want faster charging you should change the relevant settings in /sys filesystem to allow more current from the charger but the charger should be able to provide it, I think the phone goes to up a maximum of 3 Amperes. This has nothing to do with the USB port.
(07-30-2021, 04:38 AM)mouffa Wrote: I can not understand the problem. If you want faster charging you should change the relevant settings in /sys filesystem to allow more current from the charger but the charger should be able to provide it, I think the phone goes to up a maximum of 3 Amperes. This has nothing to do with the USB port.
The problem is that most of the USB-C cables don't make full contact and flicker (loose connection),
its a known hardware issue and it sucks big time for me, thats why I need to replace the female connector on the phone!
if you are sure that the problem is the female connector I would suggest that you give the board to a repair center and they will fix it with the appropriate solder paste, hot air gun and the right connector, I philosophically prefer doing the job myself but if I know exactly what happens I prefer to give it to the professional to have the best technical result
The Pine64 store sells the replacement usb recepticles.
Just a matter of dis-assemble and re-assemble.
Unless the original design is your problem ?
I plan on adding that to one of my future parts or accessory orders so I can have one "just in case"...
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
Bug PinePhone modem keeps "disappearing" Kevin Kofler 21 24,093 09-11-2026, 09:18 AM
Last Post: idice
  Pinephone + Keyboard for sale, little use ruemoo 18 15,958 08-23-2026, 12:17 AM
Last Post: Nambo
  Pinephone - broken power button rorus 14 26,559 05-17-2026, 03:52 PM
Last Post: EuvzO8
  PinePhone 16 GB – Free to a Good Home Anna 2 2,677 01-20-2026, 01:43 PM
Last Post: Anna
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 4 9,162 12-11-2025, 08:57 AM
Last Post: jakfish
  Recycling pinephone as home server mdk 6 4,730 12-01-2025, 02:57 AM
Last Post: mdk
  PinePhone, PinePhone Pro, Keyboard/Accessories for sale brb78 5 3,727 11-30-2025, 05:45 AM
  Modem Issues with the Pinephone Temmie19 5 7,310 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 5,441 06-21-2025, 05:19 PM
Last Post: mikeb
  Pinephone not booting sd card... bruv 1 3,993 03-25-2025, 08:51 PM
