Battery replacement
I just got my PBP back from a repair shop after keyboard, mouse and USB inputs all suddenly and simultaneously stopped working. The technician found that they work on mains power supply with the battery disconnected, and suggested I replace the battery. He and I both searched for the right model, but didn't find anything. Is it available anywhere?
https://files.pine64.org/doc/datasheet/p...%A6-14.pdf
Search for 40110175p
Hi everybody,
I've found a place where you can purchase replacement batteries.
Check this place: https://www.battery-store.eu/laptopcomputer/1006019.htm
(select the upper battery "Laptop battery for H-40110175P, PL3588106P-2P, NV-40110175 computer batteries")
(just in case that the above link may break in the future)
To find the above page, put the text "H-40110175P" into the https://www.battery-store.eu search box, then select the battery with "3.8V" voltage and "4.35V" max charging voltage (you need to click on the "More Info" button, to see the enlarged image).
Also check the connector, there is a second battery listed with a slightly smaller connector & only 3.8V max charging voltage, that does not fit into the Pinebook Pro.
When purchasing put the text "Pinebook Pro" into the text box "your machine model" and you are fine to go.
I'm from the EU (Austria). so purchasing replacement pieces from the pine store could be a bit tedious, because of toll, etc, and currently the Pinebook Pro replacement batteries are currently marked as "Sold Out" in the pine store. So the above store is a convenient place to fetch those batteries.
Btw also check out the Warehouse addresses: https://www.battery-store.eu/info/about_us.php
Purchasing also e.g. from the US should be simple (& toll-free).
best regards
  Replacement battery for PineBook Pro DrYak 5 9,589 02-28-2026, 09:17 PM
  Replacement main board for Developers mozes 11 14,578 11-17-2024, 04:32 AM
Last Post: reukiodo
  Replacement touch pads Sb2024 0 2,836 11-14-2024, 10:05 PM
Last Post: Sb2024
  Bad replacement battery? chris88233 4 7,211 11-14-2024, 06:05 PM
Last Post: reukiodo
  Keyswitch scissors replacement cmj 1 3,838 10-14-2024, 05:35 PM
  Lithium Battery Connector Franestra 0 3,344 04-02-2024, 01:52 AM
Last Post: Franestra
  Bypassing the Battery gilwood 0 2,865 02-01-2024, 10:45 AM
Last Post: gilwood
  PBPro Battery specification Perl6_user 3 4,935 12-26-2023, 04:28 PM
Last Post: DrYak
  Battery drain when off srs5694 1 3,515 03-24-2023, 06:05 PM
  Replacement scissor switches (ANSI keyboard)? zackw 3 8,419 08-09-2021, 09:20 PM
