I have two different versions of Chromium on my Pro!
Version 90.0.4430.212 (Official Build) Arch Linux ARM (64-bit)
Version 91.0.4472.77 (Official Build) snap (64-bit)
I want to remove the snap version from my Pinebook Pro. Is this possible?
should be entirely possible: sudo snap remove --purge package-name
(06-01-2021, 08:49 AM)tophneal Wrote: should be entirely possible: sudo snap remove --purge package-name
Your advice worked. Thank You! Big Grin
  Older Versions of the PBP Atton 3 5,181 07-13-2025, 03:54 PM
  Manjaro versions bad and good gilwood 0 2,876 02-12-2024, 05:03 PM
Last Post: gilwood
  Chromium Dino game is slow/glitchy stozi 0 3,173 04-21-2021, 08:18 AM
Last Post: stozi
  Netflix, Amazon Prime Video, and Chromium. Nobot 13 30,573 03-12-2021, 10:46 AM
Last Post: spikerguy
  Issues with chromium-docker PVD 4 10,885 12-17-2020, 10:11 PM
Last Post: warehouses
  How to flash the emmc when it has Chromium on it? U47 3 7,768 07-10-2020, 10:07 AM
Last Post: U47
  Chromium browser on PBP can't upload files on websites Wawe 0 3,419 07-03-2020, 11:06 AM
Last Post: Wawe
  How do you upgrade Chromium on default Debian that came with my PBP james64 6 13,718 05-26-2020, 07:21 AM
Last Post: User 6582
  PineBook Pro Versions? User 6582 4 13,063 04-08-2020, 03:15 PM
Last Post: fire219
  Pinebook Pro versions? geokon 5 9,667 04-08-2020, 04:27 AM
Last Post: geokon
