Anyone been able to get a working GloDroid img on SD?
#31
If you get a chance then report the problems on github to try to get it fixed.
hopefully whenever the next batch of the tabs can be made they are still similar enough to the EA version, and we can put one in rsglobal's hands. that'll certainly beat them trying to help us blindly lol
as of v0.6.1, the screen works on Glodroid+Pinetab! yay! physical keyboard works great, wifi, and bt, too. Only thing I'm noticing a lack of is display orientation/rotation.
(05-26-2021, 01:09 PM)tophneal Wrote: as of  v0.6.1, the screen works on Glodroid+Pinetab! yay!  physical keyboard works great, wifi, and bt, too. Only thing I'm noticing a lack of is display orientation/rotation.
 I flashed the image on sdcard. If i press on Bluetooth, it's crashing. The sound is also not working. Is it better to flash on emmc?
(05-29-2021, 01:45 PM)m.alizade7 Wrote:  I flashed the image on sdcard. If i press on Bluetooth, it's crashing. The sound is also not working. Is it better to flash on emmc?
unfortunately, i cannot say. i alway run into issues trying to get the standard build scripts to build the images. I used the gensdimg.sh script and am running glodriod from an SD
  Angelfish not working after installing latest image via SD catd PTCruiser 0 2,361 05-21-2024, 06:34 PM
Last Post: PTCruiser
  Working OS on pinetab RISC-V? user641 3 5,028 12-13-2023, 08:11 AM
  Udemy not working on pinetab2 (danctnix) jbreese 3 4,103 06-13-2023, 11:34 AM
Last Post: jbreese
  Important apps stopped working yurievitch 2 7,144 07-14-2021, 11:43 PM
Last Post: LisaFord
  Got Vivaldi Working on Arch! wd5gnr 3 10,921 11-09-2020, 12:13 PM
Last Post: hanscees
