New phone - has issues?
Hi.
Received the phone a few days ago. Set up and updated first time.
Battery only charges to 85% no matter what and then system shows this fluctuating wildly during use so not reliable. I understand some think this normal. I do not.
Now, after updating I cannot get into the phone. I enter my pin to unlock, it let's me into the app I had open, calendar for example, the screen flashes quickly, and then goes blank before returning to the lock screen. Repeat to fade. Even after hard restart holding power button. I am no Linux code king but this and the general sluggishness of the phone lead me to believe its flawed.
Can anyone offer guidance? I'm prepared to put up with a device that's slightly slower than I'm used to but this seems excessive and with the loop it seems stuck on, unusable.
I also wonder if anyone can advise what sort of experience, speed wise, I should expect? I have taken videos and can upload if it helps. Should I contact support to return? Thanks for any help. J.
Update - installed Manjaro Phosh on SD card and booted from that. Experience is infinitely better and as expected really so must be an OS install issue from the factory process. As soon as I get the OK from support to flash new OS I will.
So, question is: Manjaro phosh, Mobian or Sailfish?
Did you try installing an OS to an SD card and booting that? The Pinephone is no powerhouse, but it should run the same as any lower end android phone.
(05-03-2021, 11:01 AM)AndroidMancave Wrote: Now, after updating I cannot get into the phone. I enter my pin to unlock, it let's me into the app I had open, calendar for example, the screen flashes quickly, and then goes blank before returning to the lock screen. Repeat to fade.
Have you tried to set the screen timeout values using Settings -> Screen?
That writes incorrect values to corresponding file. More information here:
https://forum.pine64.org/showthread.php?tid=13744
(05-04-2021, 12:45 AM)rocket2nfinity Wrote: Did you try installing an OS to an SD card and booting that? The Pinephone is no powerhouse, but it should run the same as any lower end android phone.
Hello, thanks for the reply. No. Haven't tried anything yet for two reasons:
1 - waiting to hear from Pine Support as I don't want to void warranty etc but very happy to try Sailfish as had this years ago and loved it
2 - device will not let me navigate within it long enough to do anything useful, screen flashes and goes blank/back to pin code screen
No, not tried anything yet as waiting to hear from support - don't want to void any warranty etc or possible return and, the phone won't stay on long enough or on the correct screen or app long enough for me to do anything useful with it - keeps flashing and heads back to a blank screen and/or pin code lock screen.
Installing Sailfish to an SD card, inserting and booting from it, will not void your warranty
  Default password for KDE plasma pine phone Toni 0 8,605 09-14-2025, 06:35 PM
Last Post: Toni
  BalenaEtcher issues... gtamichael 6 5,900 03-26-2025, 09:22 AM
Last Post: gtamichael
  My new phone stopped working. gunnygee 3 5,044 12-12-2024, 01:21 PM
  Pine Phone in Australaa and Telstra tracyanne 2 3,525 12-06-2024, 02:42 AM
Last Post: tracyanne
  Can't complete update of manjaro: wwan0 stays disabled; no phone/text gilford 3 4,669 12-05-2024, 06:42 AM
Last Post: gilford
  2G, 3G still is in phone. Piotr Bujakowski 5 7,163 09-19-2024, 03:49 AM
Last Post: jennybaso
  Looking for the "non-phone" OS wakyct 7 9,576 03-14-2024, 03:51 AM
Last Post: MTXP
  Writing apps/programs for pine phone katesfb 7 13,373 03-11-2024, 10:42 PM
Last Post: Emelia525
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 4,966 01-09-2024, 07:02 PM
Last Post: britelite
  Multiple issues with the Pinephone MTXP 12 14,161 12-28-2023, 07:55 AM
Last Post: MTXP
