WARNING to future users ~ Order yourself a SIM Card Extender
If you recently ordered a PinePhone64 I highly suggest you order yourself a better SIM Card Extender.
Under no conditions should you even ATTEMPT to use the plastic one sent with the device. Iv personally verified it Will break the Sim Card Slot due to how the extender is designed (Cheap plastic, rough edges catch on prongs)
(05-02-2021, 08:35 AM)Bonesdog Wrote: If you recently ordered a PinePhone64 I highly suggest you order yourself a better SIM Card Extender.
One does have to be careful. Not all sims will hold snugly in the plastic adapter. I find it may help to put slight finger pressure over top of it as you slide it in to prevent the SIM from slipping out (and possibly catching pin).
Martijn Braam did a video covering inserting sim cards into Pinephone: https://youtu.be/SiQSJSrPqd8. The one some users have issue with is the nano sim found at 2:57 in the video.
- RTP
"In the beginner's mind there are many possibilities, in the expert's mind there are few." -Shunryu Suzuki
[ Pinephone Original | Pinetab v1 / v2 Enjoyer ]
Linux Device Privacy / Security Playlist
why would someone wan't to remove the card once its inside Wink
This is a one way trip !
(05-02-2021, 12:37 PM)fdlamotte Wrote: why would someone wan't to remove the card once its inside Wink
I Agree COMPLETELY!
I currently have managed to get a SIM card in the and Registered to the Pins but am hesitant to take it out given It might damage the pins further
However sadly the SIM card that is currently detected im not sure if it 100% works. Currently looking for a way to install Google Fi onto the device (I saw a video of someone who had a Microsd with over 20 operating systems, maybe one is just an android os for getting the Sim unlocked then use defualt OS and see if service works...)
I ordered a different extender but the one they ship in the box is 100% garbage and should not be used. (The design has rough edges that clip/stick to the interior sim card slot)
  Pinephone not booting sd card... bruv 1 3,805 03-25-2025, 08:51 PM
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 27 46,458 01-29-2023, 12:20 PM
Last Post: skandigraun
  Pinephone won't boot from SD card arkadione 3 8,315 05-25-2022, 03:26 PM
Last Post: sfb
  Any UK Pinephone users making telephone calls? GrapeJuice 4 7,439 01-24-2022, 04:37 PM
Last Post: dukla2000
  Largest supported micro SD card? zooidic 2 4,928 01-08-2022, 06:01 AM
Last Post: zooidic
  Red LED when trying to boot from SD card. Need advice. サーバント 5 10,101 10-20-2021, 09:40 AM
  Fragile SIM card connector hakkou 1 3,876 08-25-2021, 07:44 AM
Last Post: wibble
  Sd card slot death? Hurrikan 7 13,028 05-17-2021, 03:55 PM
Last Post: jrballesteros05
  Future plans for hardware daniel_mazurkiewicz 10 19,063 04-09-2021, 01:52 AM
Last Post: nilclara
  Strange SD Card Problems anhilde 7 13,071 02-21-2021, 07:52 AM
