slarm64 (unofficial slackware) Rock64 RK3328 (aarch64)
Somehow changing mac address by adding in /etc/rc.d/rc.inet1.conf 'HWADDR[0]="xxx"' didn't work anymore.
I am quite sure it used to work correctly.
Edit: Another quick question is, how am I supposed to do to clear temp files that have been downloaded during upgrading?
Hi mara,
I have tried with the latest image with kernel 5.11.11 this weekend, but it seemed not stable enough for long time running yet.
The most stable version is still 4.4.x kernel, I would hope you guys can keep updating the old but most stable kernel. I understand that the development has been mostly shifted to newer kernel, please just don't abandon the old kernel before the new ones getting more stable.
(04-26-2021, 07:58 PM)Enig123 Wrote: Hi mara,
Hi Enig123,
migration from 4.4.y will most likely be 4.19.y supported by rockchip.
donation   irradium
kernel 5.12.0
slarm64-current-aarch64-base-rock64-5.12.0-build-20210502.img.zst
slarm64-current-aarch64-base-rock64-5.12.0-build-20210502.img.zst.sha256
slarm64-current-aarch64-xfce-rock64-5.12.0-build-20210502.img.zst
slarm64-current-aarch64-xfce-rock64-5.12.0-build-20210502.img.zst.sha256
donation   irradium
update kernel 5.13.6
slarm64-current-aarch64-server-rock64-5.13.6-build-20210731.img.zst
slarm64-current-aarch64-server-rock64-5.13.6-build-20210731.img.zst.sha256
slarm64-current-aarch64-xfce-rock64-5.13.6-build-20210731.img.zst
slarm64-current-aarch64-xfce-rock64-5.13.6-build-20210731.img.zst.sha256
donation   irradium
Big Grin
I really like your project, and need it.
But how do I verify the downloaded files, the main site doesn't use https, can you provide a *.asc key verification for each file?
Or is there another way to verification the files now?
(08-14-2021, 12:17 PM)erzjbuao Wrote: I really like your project, and need it.
yes, when installing using slackpkg, the GPG validation option is enabled by default.
slackpkg update gpg && slackpkg update
donation   irradium
update kernel 5.14.1
slarm64-current-aarch64-server-rock64-5.14.1-build-20210907.img.zst
slarm64-current-aarch64-server-rock64-5.14.1-build-20210907.img.zst.sha256
slarm64-current-aarch64-xfce-rock64-5.14.1-build-20210907.img.zst
slarm64-current-aarch64-xfce-rock64-5.14.1-build-20210907.img.zst.sha256
donation   irradium
update kernel 5.15.3
slarm64-current-aarch64-server-rock64-5.15.3-build-20211120.img.zst
slarm64-current-aarch64-server-rock64-5.15.3-build-20211120.img.zst.sha256
slarm64-current-aarch64-xfce-rock64-5.15.3-build-20211120.img.zst
slarm64-current-aarch64-xfce-rock64-5.15.3-build-20211120.img.zst.sha256
donation   irradium
Installation README.TXT
update kernel 5.16.2
slarm64-current-aarch64-server-rock64-5.16.2-build-20220125.img.zst
slarm64-current-aarch64-server-rock64-5.16.2-build-20220125.img.zst.sha256
slarm64-current-aarch64-xfce-rock64-5.16.2-build-20220125.img.zst
slarm64-current-aarch64-xfce-rock64-5.16.2-build-20220125.img.zst.sha256
donation   irradium
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 13 18,696 06-27-2026, 02:43 PM
  rAudio for Rock64 V2/Pine A64+ shinzuka 11 1,856 06-25-2026, 03:16 PM
Last Post: shinzuka
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,129 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 6,030 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 11,959 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,232 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,409 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,396 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 86,659 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 110,494 09-01-2024, 06:05 AM
