Booting my RockPro64 from NVMe drive
Hello.
I see some messages that I'm not sure are ok to ignore. Hope someone can tell me something else about them.
This is my boot log from UART (minicom):
U-Boot TPL 2021.01-09768-gc762ab29b8 (Mar 20 2021 - 13:48:40) Channel 0: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB Channel 1: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB 256B stride lpddr4_set_rate: change freq to 400000000 mhz 0, 1 lpddr4_set_rate: change freq to 800000000 mhz 1, 0 Trying to boot from BOOTROM Returning to boot ROM... U-Boot SPL 2021.01-09768-gc762ab29b8 (Mar 20 2021 - 13:48:40 +0000) Trying to boot from SPI NOTICE:  BL31: v2.4(release):v2.4 NOTICE:  BL31: Built : 13:33:26, Mar 20 2021 U-Boot 2021.01-09768-gc762ab29b8 (Mar 20 2021 - 13:48:40 +0000) SoC: Rockchip rk3399 Reset cause: POR Model: Pine64 RockPro64 v2.1 DRAM:  3.9 GiB PMIC:  RK808 MMC:  mmc@fe310000: 2, mmc@fe320000: 1, sdhci@fe330000: 0 Loading Environment from SPIFlash... SF: Detected gd25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB *** Warning - bad CRC, using default environment In:    serial Out:  serial Err:  serial Model: Pine64 RockPro64 v2.1 Net:  eth0: ethernet@fe300000 Hit any key to stop autoboot:  0 Card did not respond to voltage select! : -110 Card did not respond to voltage select! : -110 Device 0: Vendor: 0x144d Rev: 2B2QEXM7 Prod: S4EUNJ0N308323A                Type: Hard Disk             Capacity: 238475.1 MB = 232.8 GB (488397168 x 512) ... is now current device Scanning nvme 0:1... Found U-Boot script /boot.scr 2226 bytes read in 2 ms (1.1 MiB/s) ## Executing script at 00500000 27260800 bytes read in 52 ms (500 MiB/s) 56812 bytes read in 3 ms (18.1 MiB/s) 27165617 bytes read in 54 ms (479.8 MiB/s) Booting Debian 5.10.0-6-arm64 from nvme 0:1... Moving Image from 0x2080000 to 0x2200000, end=3ca0000 ## Flattened Device Tree blob at 01f00000   Booting using the fdt blob at 0x1f00000   Loading Ramdisk to f051e000, end f1f063b1 ... OK   Loading Device Tree to 00000000f050d000, end 00000000f051ddeb ... OK incorrect device type in 1 Starting kernel ... [    3.917989] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: failed to create phy [    3.924167] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: failed to create phy [    3.926395] sdhci-arasan fe330000.sdhci: No phy for arasan,sdhci-5.1. [    3.947158] rk_gmac-dwmac fe300000.ethernet: phy regulator is not available yet, deferred probing [    3.958031] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: failed to create phy [    3.958918] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: failed to create phy [    3.968522] rk_gmac-dwmac fe300000.ethernet: phy regulator is not available yet, deferred probing [    4.021567] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: failed to create phy [    4.030784] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: failed to create phy [    4.033946] rk_gmac-dwmac fe300000.ethernet: phy regulator is not available yet, deferred probing [    4.049366] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: failed to create phy [    4.155651] rk_gmac-dwmac fe300000.ethernet: phy regulator is not available yet, deferred probing [    4.263085] rk_gmac-dwmac fe300000.ethernet: phy regulator is not available yet, deferred probing [    4.365919] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed /dev/nvme0n1p2: clean, 229659/15171584 files, 15424873/60674560 blocks [    7.720197] sd 0:0:0:0: [sda] No Caching mode page found [    7.720806] sd 0:0:0:0: [sda] Assuming drive cache: write through [    9.380672] Bluetooth: hci0: command 0x0c03 tx timeout Debian GNU/Linux bullseye/sid rockpro64 ttyS2 rockpro64 login: [  17.380860] Bluetooth: hci0: BCM: Reset failed (-110)
I use Armbian / Focal with a 256G Nvme (PNY)
in my dmesg log I do not see these messages except the one about Bluetooth. I already had this kind of message when I have a problem with the image I flashed (size truncated) but this is probably not your case.
(05-01-2021, 02:14 PM)LMM Wrote: Hi,
Yeah, the bluetooth is expected because I'm not using any BT module, but apparently the CRC message is non-critical and it seems to show up to other users too. And about the card not responding to voltage, seems to be from eMMC and SD card interfaces when you're not using any of them.
Edited;
There is still one message I have no idea:
my boot sequence :
U-Boot 2021.01-09768-gc762ab29b8 (Mar 20 2021 - 13:48:40 +0000) SoC: Rockchip rk3399 Reset cause: POR Model: Pine64 RockPro64 v2.1 DRAM:  3.9 GiB PMIC:  RK808 MMC:  mmc@fe310000: 2, mmc@fe320000: 1, sdhci@fe330000: 0 Loading Environment from SPIFlash... SF: Detected gd25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB *** Warning - bad CRC, using default environment In:    serial Out:  serial Err:  serial Model: Pine64 RockPro64 v2.1 Net:  eth0: ethernet@fe300000 Hit any key to stop autoboot:  0 Card did not respond to voltage select! : -110 Card did not respond to voltage select! : -110 Device 0: Vendor: 0x1987 Rev: CS303320 Prod: PNY4720003194010479F             Type: Hard Disk             Capacity: 238475.1 MB = 232.8 GB (488397168 x 512) ... is nowScanning nvme 0:1... Found U-Boot script /boot/boot.scr 3185 bytes read in 2 ms (1.5 MiB/s) ## Executing script at 00500000 Boot script loaded from nvme 0 166 bytes read in 2 ms (81.1 KiB/s) 15335962 bytes read in 32 ms (457 MiB/s) 28582400 bytes read in 55 ms (495.6 MiB/s) 75809 bytes read in 4 ms (18.1 MiB/s) 2698 bytes read in 3 ms (877.9 KiB/s) Applying kernel provided DT fixup script (rockchip-fixup.scr) ## Executing script at 09000000 Moving Image from 0x2080000 to 0x2200000, end=3de0000 ## Loading init Ramdisk from Legacy Image at 06000000 ...   Image Name:  uInitrd   Image Type:  AArch64 Linux RAMDisk Image (gzip compressed)   Data SizAddress: 00000000   Entry Point:  00000000   Verifying CheckOK ## Flattened Device Tree blob at 01f00000   Booting using the fdt blob at 0x1f00000   Loading Ramdisk to f1066000, end fOK   Loading Device Tree to 00000000f0feb000, end 00000000f1065fff ... OK Starting kernel ... [    8.210542] OF: graph: no port node found in /i2c@ff3d0000/typec-portc@22 [  10.094840] systemd[1]: Failed to start Raise network interfaces. [  10.688541] Bluetooth: hci0: command 0x0c03 tx timeout [  18.912586] Bluetooth: hci0: BCM: Reset failed (-110) Armbian 21.02.3 Focal ttyS2
I have not activated much log (verbosity =2 in armbianEnv.txt)
Perhaps due to your second partition nvme0n1p2 ?
(05-02-2021, 01:56 AM)LMM Wrote: my boot sequence :
Sorry peeps I completely missed these messages.
I even forgot I had account here!
I need to come here more often!
I don't even remember why I came here about the messages. Probably just out of curiosity.
I'm using Debian Buster for this architecture, if this matters!
  RockPro64 automatically run after power recovery - my solution g2t 1 1,693 05-28-2026, 05:29 PM
  where to get debian 12 image for rockpro64? heocb 1 4,391 05-18-2025, 02:30 PM
Last Post: Dendrocalamus64
  Use android on RockPro64 without a LCD screen ? john_nash 0 3,711 03-28-2025, 11:15 PM
Last Post: john_nash
  How to use ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card jykeith123 1 5,453 11-26-2024, 11:08 AM
  Installing Wifi drive for the RockPro64 John45595 0 4,661 02-10-2024, 11:32 PM
Last Post: John45595
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 226,162 09-25-2023, 12:46 AM
Last Post: ChriChri
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 6,153 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 4,852 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 13,792 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 5,144 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
