keep getting thrown out of pinephone??!
Hello, I am new to this forum. I am running a pine phone beta addition with manjaro/plasma mobile. a lot of the time when I sign in i got locked out have to re sign in re do my pin password
(04-25-2021, 12:35 PM)radioheadfan Wrote: Hello, I am new to this forum. I am running a pine phone beta addition with manjaro/plasma mobile. a lot of the time when I sign in i got locked out have to re sign in re do my pin password
Are you saying your screenlock? Change your settings to make the screenlock timeout longer if you would like it to wait longer. Usually in power related settings.
- RTP
"In the beginner's mind there are many possibilities, in the expert's mind there are few." -Shunryu Suzuki
[ Pinephone Original | Pinetab v1 / v2 Enjoyer ]
Linux Device Privacy / Security Playlist
No I mean that it sends me to the lock screen randomly when I have just log in. I have changed it so it will not automaticaly switch of the screen but that has do nothing to help.
Maybe the same problem: https://forum.pine64.org/showthread.php?tid=13481
no it is completely chucking me of the phone and requireing me to log in/ input pin every few seconds.
(04-28-2021, 08:56 AM)radioheadfan Wrote: no it is completely chucking me of the phone and requireing me to log in/ input pin every few seconds.
That was very similar here Smile
What you can try is to connect charger - does the display stay on then?
If yes, you can try to manually edit the file: /.config/powermanagementprofilesrc to have similar values like in this post:
https://forum.pine64.org/showthread.php?...8#pid93468
to sii if that helps Wink
I have done that and download some updates which have been good to mean but the issue is some what still around.
I am having what you had in which it is fine and dandy when the charger is in but not so much when it is not.
  Zig booting up on PinePhone WhiteHexagon 0 3,512 07-19-2025, 03:11 AM
Last Post: WhiteHexagon
  Optimizing Power Management on PinePhone with PostmarketOS ZaraAbbas 0 3,894 05-27-2025, 01:49 AM
Last Post: ZaraAbbas
  Second-Hand PinePhone rdv 9 8,127 01-05-2025, 11:42 PM
  pinephone 3 ideas aular 5 6,749 11-08-2024, 06:35 AM
  PinePhone Pro and PinePhone Community Edition Different SIM Card Trays dorkydev 2 4,175 04-11-2024, 03:10 PM
  Where PinePhone Pro are Made Tony90 1 4,896 01-18-2024, 09:20 AM
  using Zoom on Pinephone andrew907 5 6,244 12-09-2023, 01:26 AM
Last Post: crocspot
  Does pinephone allow you to repair your own device as easily as fairphone? unix21311 3 6,226 11-06-2022, 10:37 PM
Last Post: Harolddavies0
  can i install mobian on pinephone? luofeiyu 2 4,021 10-15-2022, 07:31 AM
Last Post: user641
  Does the pinephone have hardware kill switches located on the outside of the phone? unix21311 2 10,220 10-03-2022, 05:53 AM
Last Post: unix21311
