lost eth0 on my pine64
Hi all
newbies on Pine64 and  armbian I cannot connect network using ethernet connector
just installed armbian today and the wlan is working fine but system looks cannot fine eth0
the debian version used is
cat debian_version
10.7i
now I used armbian-config to setup the Wifi but here eth0 is no more present....
I don't know where I can go to enforce driver or something like that ... I more Windows users ;-)
Thanks in advance for your support ...
Furthemore my english is not perfect I'm French
Pierre.
try adding the following in /etc/network/interfaces :
# Wired adapter #1
allow-hotplug eth0
iface eth0 inet dhcp
it could also be an issue with the driver. there's a post on armbian's forum, that discussed the eth0 driver not working after the kernel update to 5.8. My A64+ is running Armbian and has a similar problem, so I just use the wifi connection.
still doesn't work :-(
afraid to stay like you only on Wifi doesn't work for my project to drive 3D printer with that ...
Is your board an A64 LTS or + (pre LTS IIRC)? You might try a different distro. Arch should work on it very well.
(02-16-2021, 12:39 PM)tophneal Wrote: Is your board an A64 LTS or + (pre LTS IIRC)? You might try a different distro. Arch should work on it very well.
I'll Try longtime ago I bought it so what I know is Pine 64 with 512 of memory nothing is wrote in the board.
However I already try Suse & Fedora without success (no boot) so why not I'll try Arch ditrib
I'll give you feedabck as soon as I can download it basedI have an error to download it with My PC
Regards
I have both A64-LTS and the (old) A64 running and had no issues with eithernet whatsoever using Debian/Devuan. I assume that you could have an issue with your bootloader (u-boot). Can you see the ethernet being listed in u-boot on the serial console?
Hi kuleszdl
Thank for your answer, to be honest, I don't know how to check the u-boot :-( newbie on linux and Pine too
at this time I start to learn by myslef with tuto and whatever ;-)
otherwise I finished to install Pi-hole on it and is looks running well using only the Wifi
But if yo explain the way to check the U-boot I'll do of course
Regards
Well it's not really trivial to check u-boot once you flash it, you typically have to check whether you are flashing the particular u-boot version before you flash it.
You can follow the official Debian wiki using the "Installing from an SD card image" approach:
https://wiki.debian.org/InstallingDebianOn/Allwinner
The files for the A64 can be found here (you need partition.img.gz and firmware.pine64_plus.img.gz - don't worry the A64 and the A64+ need the same u-boot, the A64 LTS does not):
https://deb.debian.org/debian/dists/stab...rd-images/
  ROK OS v7 OK Bitcoin Fullnode OpenBazaar for Pine64+ OKtoshi 9 28,087 05-21-2021, 12:14 PM
Last Post: killor
  Debian Pine64 h264/5 Video under vlc ozcy 6 20,777 04-15-2020, 05:27 AM
Last Post: dmitrymyadzelets
  Debian 10 (Buster) in deep freeze - includes support for Pine64+ amp 5 17,114 07-22-2019, 09:29 PM
Last Post: amp
  Pine64 Debian Stretch/mainline [4.14.7] CallMeFoxie 50 167,206 07-22-2019, 09:24 PM
Last Post: amp
  Script to build pure Debian images for Pine64+ amp 1 7,892 05-01-2019, 09:09 PM
  Debian (Stretch) for Pine64-LTS wgray 2 11,237 04-04-2019, 09:54 PM
Last Post: wgray
  Announcement: OMV (OpenMediaVault) for PINE64 DuDu371 11 44,371 12-07-2018, 09:52 PM
Last Post: flinkazoid
  Debian Stretch on Pine64 (run rock64 images on pine64) douglasmiranda 3 10,592 07-25-2017, 11:14 PM
Last Post: douglasmiranda
  pine64 not booting bgwATbewas 4 10,973 02-07-2017, 01:07 PM
Last Post: Luke
  Docker 1.12 on Pine64 ? guidtz 6 15,370 12-04-2016, 01:54 AM
Last Post: umiddelb
