Not charging, not detected when booting jumpdrive
Okay, so I made this thread, PinePhone replacement board won't stop vibrating, detailing how I basically cut of the vibration motor from the sideboard after it started malfunctioning with the newest version of the PinePhone boards. One thing I didn't make a post about was the fact that I ultimately couldn't flash another OS onto the eMMC because I couldn't detect the device when booting jump drive. I used multiple versions. Furthermore, the latest build of Mobian which I booted off of an sd card didn't indicate that it was charging when the phone was plugged in. And the phone wouldn't charge.
So, I bought a new sideboard, installed it, and the same issues are still there. No light when plugged in, although, it's been about a year since my Pinephone even worked, so I'm having a hard time remembering what it does when it charges. No vibration issues, though. It's plugged in now, and it doesn't seem to have increased in battery since it was plugged in. Lsblk doesn't return anything when the phone is booted into jumpdrive. I tried this on another laptop with Ubuntu, but no dice. I've flashed the eMMC on this phone plenty of times using this exact cable, so I don't think it's that.
I also bought a replacement screen, so maybe I'll see how that goes. At that point, this is going to be the Theseus' ship of PinePhones. I really hope it manages to float, somehow, at this point. The sunken cost fallacy only stays in effect for so long.
Edit: Nope, nothing changed. I'm not sure why I thought it would. Perhaps the connector from the mainboard to the sideboard is damaged? If that's the case, I don't see any damage. The pins look fine, and the cable itself doesn't seem worn down.
The ribbon of my new sideboard snapped off, somehow, so I'll be using the old sideboard from now on.
What a nightmare…
  Pinephone not booting sd card... bruv 1 3,966 03-25-2025, 08:51 PM
  Jumpdrive boots Computer(s) don't recognize PinPhone sfb 0 3,223 10-11-2024, 05:47 AM
Last Post: sfb
  PinePhone Pro not booting (Cap error!, pctl timeout) jealda 2 5,091 11-16-2023, 05:03 AM
Last Post: DrYak
  modem not detected al_x 3 9,374 02-15-2023, 11:17 AM
Last Post: fxc
  Charging Indicator On - Not Charging SJSEng 0 2,339 08-30-2022, 07:33 AM
Last Post: SJSEng
  PPKB with phone; phone dies while charging SwordfishII 1 4,061 06-08-2022, 04:14 AM
Last Post: SwordfishII
  Battery mot charging past 54% StickyPine 32 53,579 02-26-2022, 02:07 AM
Last Post: vusra
  Convergence: battery is constantly discharging/charging arjan1995 5 8,943 06-04-2021, 02:38 AM
Last Post: dsimic
  Wifi/BT interface not detected aithal 17 29,685 05-30-2021, 11:10 AM
Last Post: Krasimir
  Pinephone charging issues after fully depleting battery. plainenough 13 26,759 04-07-2021, 09:44 AM
Last Post: wibble
