Manually mount SD card in running system?
I haven't found a distro yet that will automatically mount an SD card in the phone. I'm running Manjaro Plasma beta2 right now. Why doesn't the SD card automount when booting the phone? I've made sure that the SD card isn't bootable, so it doesn't interfere with booting the phone. The SD works fine when it contains an OS image or the jump drive.
How do I go about manually mounting the card? I want to use it for file storage, music, etc.
Thanks for your help!
I just tried Manjaro Phosh beta6 (Manjaro-ARM-phosh-pinephone-beta6.img.xz), and it comes with a Disks app, which lets me manually mount the SD card, so I have a way to do this now. I successfully read an image off an SD card and displayed it using the image viewer app.
Alternatively, you can mount it with
sudo mount /dev/mmcblk0p1 /your/folder
not sure about plasma, but in phosh i have /dev/mmcblk2 as an internal emmc storage and /dev/mmcblk0 as an sd card
you may also want to mount it on boot automatically, then you'll need to add it to fstab
(03-03-2021, 11:24 AM)Nick_dnepr Wrote: Alternatively, you can mount it with
not sure about plasma, but in phosh i have /dev/mmcblk2 as an internal emmc storage and /dev/mmcblk2 as an sd card
Ah, that's the device name! Thanks. That makes sense. I'm trying Phosh right now, but I'll check that out on Plasma, too.
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 10 19,775 10-04-2024, 12:01 AM
Last Post: spazz
  How do I import SIM card contacts? Logological 8 15,060 06-04-2023, 12:49 PM
Last Post: mruser1
  Can't add micro SD card to Pinephone thorensjubilee 7 9,066 02-27-2023, 10:21 AM
Last Post: mikehenson
Question Running AnBox on Manjaro ARM w/ Phosh? danimations 2 5,865 09-05-2022, 03:42 PM
Last Post: nroth
Question Problem with booting from SD card. Several errors LittleStone 0 2,351 09-04-2022, 02:34 PM
Last Post: LittleStone
Question Help installing Snaps on Pinephone running Manjaro ARM w/ Phosh danimations 2 4,735 04-07-2022, 06:02 AM
Last Post: danimations
  Error running docker on Pinephone with Manjaro (cgroup) bchasnov 0 3,519 01-06-2022, 12:19 PM
Last Post: bchasnov
  Phone doesn't mount on laptop lsitongia 2 6,416 03-02-2021, 08:29 AM
Last Post: lsitongia
  System keeps turning modem off -2 part issue? KNERD 1 3,807 01-26-2021, 05:59 PM
Last Post: insomagent
Sad Cannot play songs directly from SD card SameExpert 2 5,945 01-25-2021, 04:33 AM
Last Post: SameExpert
