Wifi doesn't see 5 GHz network
None of the distributions I've tried will let me connect to my 5 GHz wifi network at home, because it only shows the 2.4 GHz. The hardware supports 802.11n, so why doesn't it show my higher speed access points?
I have the Mobian CE with Convergence.
Thanks!
(03-01-2021, 03:18 PM)lsitongia Wrote: None of the distributions I've tried will let me connect to my 5 GHz wifi network at home, because it only shows the 2.4 GHz. The hardware supports 802.11n, so why doesn't it show my higher speed access points?
Thanks!
The Pinephone wifi hardware only supports 2.4 GHZ.
The spec for the phone says 802.11b/g/n. n is 2.4 and 5. That's according to Wikipedia. So, Pine64 doesn't implement 5 GHz. Okay, thanks for your help.
(03-01-2021, 03:50 PM)lsitongia Wrote: The spec for the phone says 802.11b/g/n. n is 2.4 and 5. That's according to Wikipedia. So, Pine64 doesn't implement 5 GHz. Okay, thanks for your help.
I've seen other 802.11n devices that support 2.4 GHz only, like the Asus RT-N16 router I had around 10 years ago. These days it is kind of an odd limitation. For what it's worth the specifications listed for the Pinephone in the store specify that the wifi is "single-band".
Oh, okay. I understand. Thanks for your help!
Thanks!
5GHz wifi is 802.11ac. (or better).
As per the shop and the wiki the PinePhone supports 802.11b/g/n, n being an improvement of g, g being an improvement of b, all in the 2.4GHz range.
Exclamation No wIfI after Mobian update crakabeats 5 8,748 02-28-2026, 04:18 PM
Last Post: baptx
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 3,165 04-02-2024, 11:50 AM
  How To Share The External MicroSD Folders and Files On A Network? pinephoneuser22 5 7,169 02-10-2024, 08:47 AM
Last Post: jakfish
  New Zealand network providers mobile data Linux2thabone 3 7,022 08-05-2023, 06:17 AM
Last Post: SchizoPinePhone225
  USCellular network rnelsen 2 4,241 05-29-2023, 07:03 PM
Last Post: rocket2nfinity
  Pine Phone Doesn't Recognize New MicroSD Card _radv_ 3 4,921 11-23-2022, 05:19 AM
Last Post: _radv_
  Can't connect to cellular network phytocube 0 3,351 06-18-2022, 05:20 PM
Last Post: phytocube
  My Pine doesn't allow me to install to eMMC on different OS's Kimberley van Buyten 1 4,112 05-31-2022, 04:26 PM
Last Post: fxc
  plasma-dialer doesn't call Ant 7 10,283 04-08-2022, 03:09 PM
Last Post: israel
  WIFI doesn't stay connected Matt73 0 2,022 03-10-2022, 08:10 AM
Last Post: Matt73
