Plex server
#31
I think I got the same error and even with that error is working (In my case).
Heart PINE64: StackExchange Community => PINE64 Commmunity Proposal.
Proposal Status Link to Forum=> PINE64 Status Forum
Remenber to Upvote Proposed questions. And give a Follow.
#32
Thumbs Up
I was able to install Plex without a problem by following what tkaiser said to do step by step. If you are not going to follow the directions I really do not find it fair to ask him for help.  The image he points to for Debian works great. I installed it and actually did some stress testing and found I could stream 5 1080P videos to 5 different devices. 2 of them were trans coding. (Audio only)
Thanks tkaiser
#33
This one then?
http://forum.pine64.org/showthread.php?tid=376
I'm gonna try it, but network it's damn slow with that...
EDIT: No, that image doesn't work either... please, could anyone paste a link with the working image? I've tried a bunch of them, but I'm out of luck...
#34
(05-09-2016, 05:24 PM)malevolent Wrote: This one then?
https://www.stdin.xyz/downloads/people/l...es/ubuntu/
That is the one I used. It worked great if you want to do a headless Plex Server
#35
I tried xenial-pine64-bspkernel-20160507-1.img.xz yesterday, it failed, I'm going to try xenial-pine64-bspkernel-20160424-1.img.xz right now...
#36
(05-10-2016, 12:09 PM)malevolent Wrote: I tried xenial-pine64-bspkernel-20160507-1.img.xz  yesterday, it failed, I'm going to try xenial-pine64-bspkernel-20160424-1.img.xz right now...
What failed?
#37
All my images work - it does not matter which one you try.
#38
Pals... I don't know, really... Sad
I put the logs, if you could take a look on actions, perhaps you can see what I'm doing wrong...
http://pastebin.com/nE8sMFDy
Thank you...
What failed?
Both
#39
What do you need? It cleary states what is wrong in your log "as repository 'https://dev2day.de/pms jessie InRelease' doesn't support architecture 'arm64'" - what else do you need?
#40
(05-10-2016, 01:24 PM)longsleep Wrote: What do you need? It cleary states what is wrong in your log "as repository 'https://dev2day.de/pms jessie InRelease' doesn't support architecture 'arm64'" - what else do you need?
Perhaps I'm not understanding anything, but as fas as I can understand, plex installs on that device with this repo... and if I didn't understand either wrong what others said, they could it make it work on pine64 with those steps. I even saw a screenshot of plex working on it.
Am I understanding it bad?
  Mastodon instance \ Nextcloud Server fearg 1 7,309 03-31-2020, 08:18 PM
  Turn your Pine64 into a music server with mpd JulianM 2 14,505 03-23-2017, 10:50 PM
  Plex server arghne 48 78,466 03-22-2017, 04:15 AM
Last Post: pineadmin
  Pine64 as NAS/Media Server VandaL.pr! 1 8,257 12-27-2016, 10:48 AM
Last Post: Luke
  3d printer server oldsmarracin 3 8,309 09-13-2016, 02:43 AM
Last Post: JAYJAYN
  Cannot install Plex Media Server under Arch Linux malevolent 2 8,332 09-11-2016, 12:20 PM
Last Post: ChrisLane
  Building Stratum One NTP Server lospinos 5 13,539 08-23-2016, 09:23 AM
Last Post: MarkHaysHarris777
  Starbound Server. Is the Pine64 capable? iamfallen 1 5,823 08-03-2016, 10:36 AM
Brick Minecraft Server chrislink14 16 40,581 05-06-2016, 08:03 AM
Last Post: jeremycobert
  Media server montero65 3 9,087 04-28-2016, 06:02 PM
Last Post: queonda
