Phone doesn't mount on laptop
When Jump Drive is running on the phone, plugging it into my Manjaro Plasma laptop via USB mounts the phone as a storage device. On the laptop, I can see the phone's eMMC and the SD card. But, when Manjaro Plasma mobile is flashed to the phone's eMMC and up and running, plugging it in doesn't mount anything. Nothing is logged on the laptop when the USB is plugged in and removed. I'm using the same red USB cable that came with the phone in both cases, Jump Drive and running system. What is different?
How do I get the phone to mount as a storage device on my laptop?
I'm running Manjaro Plasma mobile beta2.
Thanks!
When you use Jumpdrive, it uses a special u-boot mode to expose the flash devices as mass storage. If you boot a normal OS, that feature is not something that comes as default behavior since the USB port is usually used in host mode, so you need to set that up yourself, filling in a device descriptor in sysfs and then exposing it to the outside world... roughly along the lines of https://linuxlink.timesys.com/docs/wiki/...le_Storage
Ah, I see. That makes sense. Thanks for your help!
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 4,091 07-03-2024, 08:38 PM
  New phone, KDE desktop settings reset on reboot zzb0 2 6,431 10-15-2023, 10:19 PM
  How to create folders and re-org my phone desktop? A better "Image Viewer" app? nbh 0 3,113 09-24-2023, 05:18 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 17,209 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  New issue with phone calls kmsgli 13 18,939 08-15-2022, 01:45 PM
Last Post: Gon
  Vivaldi Browser doesn't start keyboard for text entry tckosvic 1 5,138 05-24-2022, 11:32 PM
  Phone goes to sleep whilst audio playing new2pinephone 0 2,782 12-22-2021, 05:50 PM
Last Post: new2pinephone
  After fresh install outbound phone calls not working. tckosvic 2 5,198 11-10-2021, 10:45 AM
Last Post: tckosvic
Music Can only hear/speak during a phone call when on speakerphone danimations 4 8,217 10-24-2021, 11:47 PM
Last Post: danimations
  Installed Sim phone not working kmk7x 3 6,069 10-24-2021, 11:43 PM
Last Post: bcnaz
