Wake up from charging problem
(02-22-2021, 01:02 AM)j4n3z Wrote:
(02-21-2021, 10:12 AM)scholbert Wrote:
(02-21-2021, 05:17 AM)j4n3z Wrote: OK, so I tested on updated system and spotted no difference in behaviour. Through the day I managed to drain battery twice so I performed 2 full charges and both of them ended in inability to wake up. I had to reboot the device
don't know from which image you started, but maybe you should check if crust firmware is still properly installed on your system.
Try:
sudo dpkg --list crust*
A few weeks ago some packages got re-arranged, and coming from a base image published in Dec. 2020, i realized it got lost on my device at some point during my weekly update processes.
You should just check... and re-install crust if necessary
Regards,
scholbert
I flashed mobian-pinephone-phosh-20210216.img but dpkg returned nothing. So I installed crust-firmware and try again.
Thanks for helping!
As of firmware update, I followed instructions on Wiki and dmesg did not return message about outdated firmware.
According to a remark of a-wai it is not required to install the crust-firmware package.
See this as a reference: https://forum.pine64.org/showthread.php?...2#pid90342
I'm sorry for any confusion....
Regards,
scholbert
Try:
Regards,
scholbert
Thanks for helping!
Regards,
scholbert
Thanks for info, I've read through that thread as well. So far I have probably strange solution for this problem - I did not rename mobian user to custom one. It seems something is not right when I go through tweaks described on Mobian wiki to change username.
However I am not sure if I should mark it as solved because I don't feel like it was solved Big Grin
  Mobian MMS/SMS text problem bcnaz 16 41,209 06-23-2026, 06:53 AM
Last Post: mehdy
  troubleshooting sleep/wake button on trixie biketool 5 5,223 05-04-2025, 08:11 PM
  Unable to wake up from suspend xavi92 6 7,796 07-28-2024, 02:48 PM
Last Post: dchang0
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 18,736 08-31-2023, 12:38 PM
Last Post: vusra
  MODEM - Usb problem & couldn't query SIM slots: QMI protocol freelectro 5 11,239 06-06-2023, 06:36 AM
Last Post: freelectro
  Best way to wake up and check emails? DrPlamsa 7 12,874 12-31-2022, 10:57 AM
Last Post: DrPlamsa
  Does tow-boot allow periodic wake from suspension to check for notifications? DrPlamsa 4 7,238 12-31-2022, 10:56 AM
Last Post: DrPlamsa
  Is there a smart-wake yet? DrPlamsa 6 8,164 12-31-2022, 10:55 AM
Last Post: DrPlamsa
  Battery problem with a Pinephone keyboard and Mobian elode 2 5,870 12-22-2022, 07:10 PM
Last Post: acid andy
  Problem updating gilwood 5 7,767 06-09-2022, 08:27 AM
Last Post: gilwood
