broken connector-pin for the accu
Hallo together,
after 3 weeks testing the phone with different OS - today happend a tiny damage with substantial effect.
The left of 4 contacts broke and the phone is sadly unusable.
When I look at the expanded mainboard I think it would be possible to replace the contact-group by soldering. But where to get such part? Or must I buy a new PCB?
https://wiki.pine64.org/wiki/PinePhone_c...#P.6_POWER
You're looking for J600 - it seems like there might be at least 2 manufacturers. As to where to get them in small quantities, I'm not sure. You can try your local equivalent of Mouser, DigiKey, RS, Farnell, Newark etc. or see what's on offer on Ali, ebay etc.
to be honest i doubt that you will be able to get the original part somewhere.
... but i had a closer look at the connector and tried to find out some specs to search for possibly equivalent parts.
So it seems the pitch of the battery connector is metric -> 2.5mm.
Obviously it's a part with 4 activ contacts and 2 solder joints... and it's a 90° type.
I found this one at Digikey:
https://www.digikey.de/product-detail/de...ND/2001013
This is no exact replacement, but you may consider this as a reference for further investigations Shy
Good luck!
scholbert
  Pinephone - broken power button rorus 14 26,285 05-17-2026, 03:52 PM
Last Post: EuvzO8
  Battery connector dead mdk 5 5,348 01-15-2026, 02:24 PM
Last Post: mikeb
  USB-C connector Overheated and melted nickbenjones 2 5,356 05-26-2023, 06:16 PM
  Keyboard support broken in Mobian? MacarioMorenoUK 2 4,971 06-08-2022, 02:34 AM
Last Post: MacarioMorenoUK
Sad Have I got a broken camera module? AKD251 2 5,114 11-07-2021, 11:12 AM
Last Post: beta-user
  GPS Antenna - external connector? GregH 14 24,584 09-09-2021, 09:24 AM
Last Post: HobanWashburn
  Fragile SIM card connector hakkou 1 3,903 08-25-2021, 07:44 AM
Last Post: wibble
  USB C connector loose? bceverly 3 6,551 08-10-2021, 09:44 AM
Last Post: c3l@
  [Help] SIM slot contact broken WinstonSmith 3 8,318 07-14-2021, 06:13 AM
Last Post: mouffa
  PinePhone won't boot, U-Boot seems to be broken Marcade 8 15,085 04-20-2021, 05:28 PM
Last Post: dsimic
