PinePhone Cross Compiler Install
I'm trying to install a GCC cross compiler so I can write so really bad code for when my PhinePhone gets here; a 5th grader is probably a better coder then I am.
Anyway, I'm using these instructions, and it work just fine untill I try to install glibc
https://preshing.com/20141119/how-to-bui...-compiler/
make -j4 csu/subdir_lib
returns this
make[2]: *** [/home/dgdimick/PinePhone/CrossCompiler/build-glibc/sysd-rules:9: /        home/dgdimick/PinePhone/CrossCompiler/build-glibc/csu/libc-start.o] Error 1
make[2]: *** Waiting for unfinished jobs....
check_fds.c: Assembler messages:
check_fds.c:81: Error: no such instruction: `brk '
make[2]: *** [../o-iterator.mk:9: /home/dgdimick/PinePhone/CrossCompiler/build-g        libc/csu/check_fds.o] Error 1
In file included from ../include/errno.h:25,
                from ../csu/libc-tls.c:20,
                from ../sysdeps/aarch64/libc-tls.c:19:
../sysdeps/aarch64/libc-tls.c: In function ‘__tls_get_addr’:
../sysdeps/aarch64/nptl/tls.h:91:19: error: ‘__builtin_thread_pointer’ is not su        pported on this target
  91 |  (((tcbhead_t *) __builtin_thread_pointer ())->dtv)
../sysdeps/aarch64/libc-tls.c:30:16: note: in expansion of macro ‘THREAD_DTV’
  30 |  dtv_t *dtv = THREAD_DTV ();
make[2]: *** [/home/dgdimick/PinePhone/CrossCompiler/build-glibc/sysd-rules:485:        /home/dgdimick/PinePhone/CrossCompiler/build-glibc/csu/libc-tls.o] Error 1
make[2]: Leaving directory '/home/dgdimick/PinePhone/CrossCompiler/glibc-2.29/cs        u'
make[1]: *** [Makefile:258: csu/subdir_lib] Error 2
make[1]: Leaving directory '/home/dgdimick/PinePhone/CrossCompiler/glibc-2.29'
make: *** [Makefile:9: csu/subdir_lib] Error 2
dgdimick@Samba:~/PinePhone/CrossCompiler/build-glibc $
Any ideas? Or am I just doing this wrong, like there's already as package to install?
I'm running on an old laptop that has Ubuntu installed.
I would expect ubuntu to have a packaged crossdevelopment toolchain available - there's gcc-aarch64-linux-gnu at least. It probably depends which distro you're targeting though - for example PostmarketOS has a script that builds its own crossdev environment.
Here's a couple of instruction/discussion pages on cross compilation for Gentoo, maybe you will find these useful or get some direction from reading these:
https://wiki.gentoo.org/wiki/Cross_build_environment
https://forums.gentoo.org/viewtopic-p-8024368.html
  Pinephone visibly losing power while plugged in Hiraghm 9 9,261 08-29-2026, 11:18 AM
Last Post: baptx
  Pinephone software Csanderson0313 3 1,846 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 87,700 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 26,426 03-25-2026, 12:55 PM
Last Post: baptx
  pinephone-support package not upgradable on Mobian fhireman 5 8,825 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,714 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 5,295 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 2,970 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,338 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 8,720 10-21-2025, 12:12 PM
Last Post: Richy_T
