Where is the Pinephone eMMc?
In a few words, all operating system images that are available for the PinePhone are already "crafted" in a way that puts the boot loader (U-Boot) where it is expected by the mask ROM (also known as Boot ROM or BROM) inside the A64 SoC.  Thus, all that's needed is to simply write an image to a card.
Thanks, dsimic. Yeah, I forgot that Allwinner is pretty straight forward. Other boards not so much, but I don't want to confuse the issue any further, within the context of Pine64 forums.
Cheers,
TRS-80
Protocols, not Platforms
As a side note, here's an interesting issue that I haven't found mentioned anywhere.
After booting from a Micro SD card and writing the image to the eMMC, if you boot the phone (or laptop) again from the same SD card, it might happen that the /boot partition from the eMMC gets mounted in Linux instead of the same, correct /boot partition on the SD card.  Then, if you perform some system changes or updates that alter the contents of /boot, such as updating the kernel packages, you end up with one part of the updates applied to the wrong /boot partition.
The solution is to change the label of the /boot partition on the SD card prior to using it for subsequent boots, so the label is no longer the same as the label of the /boot partition on the eMMC.
Edit: Actually, the same can also happen to the root partition.
Bug PinePhone modem keeps "disappearing" Kevin Kofler 21 24,195 09-11-2026, 09:18 AM
Last Post: idice
  Pinephone + Keyboard for sale, little use ruemoo 18 16,071 08-23-2026, 12:17 AM
Last Post: Nambo
  Pinephone - broken power button rorus 14 26,623 05-17-2026, 03:52 PM
Last Post: EuvzO8
  PinePhone 16 GB – Free to a Good Home Anna 2 2,694 01-20-2026, 01:43 PM
Last Post: Anna
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 4 9,177 12-11-2025, 08:57 AM
Last Post: jakfish
  Recycling pinephone as home server mdk 6 4,767 12-01-2025, 02:57 AM
Last Post: mdk
  PinePhone, PinePhone Pro, Keyboard/Accessories for sale brb78 5 3,764 11-30-2025, 05:45 AM
  Modem Issues with the Pinephone Temmie19 5 7,354 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 5,472 06-21-2025, 05:19 PM
Last Post: mikeb
  Pinephone not booting sd card... bruv 1 4,004 03-25-2025, 08:51 PM
