SMS notification inconsistent and Wifi issue (waking up?)
Anyone know about notifications?
If I use King's Cross terminal to do:
systemctl suspend
then when a text message comes in I seem to get only a blue blinking LED due to the King's Cross command notification success (from when I suspend). So no audio warning for received SMS.
Even though I have Settings - Applications - King's Cross - Off for everything!
It seems as though the King's Cross 'Command Completed' notification just has the flashing blue LED (no sound) or the fact it is in the queue prevents the Chatty 'New Message' notification jingle to come through....
sudo pkill chatty post means you don't get notifications until you open Chatty (I think).
I'll let the phone autosuspend and see how it goes (with A sudo pkill chatty pre for now).
Note I managed to just get the modem turn on without a blue blinking LED or an jingle so not clear what is happening.....(when incoming SMS).
How is the wifi with your script ? Does it help ?
(01-21-2021, 02:28 AM)as400 Wrote: How is the wifi with your script ? Does it help ?
@as400
I'd say more testing needed, but with wifi off, then waiting for suspend / systemctl suspend, whenever I've sent a test SMS (even if the notification failed), whenever I turned wifi on I had no problem - sometimes it was slow to connect but I haven't had the weird behaviour observed previously.
I'm trying it now with wifi on, then suspend. Seems ok, too.
I'd say so far so good and seems to be the right solution to the right problem (for wifi).
Happy to hear from others!
Thanks for the systemd suggestion, I've learnt something new.
  reset wifi hardware/driver when it dies through console on pp? tuxcall 5 6,764 03-10-2026, 04:43 PM
Last Post: baptx
  Mobian Pinephone Notification LED biketool 2 3,879 06-07-2025, 03:19 PM
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 7,368 02-20-2025, 02:47 PM
Last Post: puffchumpy
  New keyboard issue sandspur 30 38,440 01-13-2025, 01:37 AM
  System won't suspend due to suspention notification user641 6 7,952 09-24-2023, 05:47 AM
Last Post: user641
  GStreamer Camera Issue (Unsupported pixformat: 0x56595559 with mbus code: 0x3001) sog8b 1 3,717 07-17-2023, 01:49 AM
Last Post: junelung
  Wifi doesn't work after update nickolas 2 4,541 04-14-2023, 10:07 AM
Last Post: nickolas
  Recent install, no wifi user641 3 4,742 01-12-2023, 03:06 PM
Last Post: user641
  Possible solutions to the battery draining issue? 3x5co 5 7,718 11-28-2022, 10:58 AM
Last Post: 3x5co
  Wifi issue since last update and held back updates goku499 11 15,082 09-21-2022, 02:39 PM
Last Post: Katsujinken
