PinePower + PinePhone?
Question
I've recently had the displeasure of trying to find a USB-PD charger, having to wade through numerous "fast charging" USB chargers with no indication of whether it meant USB-PD, Qualcomm QC (never mind which revision), Samsung's Adaptive Fast Charging, or any other one from the myriad of other fast charging protocols. After finally finding one, it (unsurprisingly) still didn't work with the PinePhone, probably due to the incomplete anx7688 driver.
The recent release of the PinePower and improvements of the aforementioned driver renewed my interest, however. Has anybody tried charging their PinePhone with the PinePower? Does PD work (reliably) or does it too charge at 1.5A? Which distro and kernel version were you on?
1.5A is the typical limit that most kernel/distros set.
It is up to yourself to change the values, if you want something different.
(01-12-2021, 10:03 AM)Alho Wrote: 1.5A is the typical limit that most kernel/distros set.
There's a very good reason for the 1.5A limit, it's according to the spec. From USB article on Wikipedia:
Quote:
  • Battery Charging Specification 1.1 Added support for dedicated chargers, host chargers behavior for devices with dead batteries
  • Battery Charging Specification 1.2: with increased current of 1.5 A on charging ports for unconfigured devices, allowing High Speed communication while having a current up to 1.5 A and allowing a maximum current of 5 A
USB-PD allows safely negotiating a higher voltage and current. Playing around with kernel voltage limits via sysfs isn't ideal, which is why I asked about people's experiences with the PinePower. Wink
Bug PinePhone modem keeps "disappearing" Kevin Kofler 21 24,093 09-11-2026, 09:18 AM
Last Post: idice
  Pinephone + Keyboard for sale, little use ruemoo 18 15,958 08-23-2026, 12:17 AM
Last Post: Nambo
  Pinephone - broken power button rorus 14 26,559 05-17-2026, 03:52 PM
Last Post: EuvzO8
  PinePhone 16 GB – Free to a Good Home Anna 2 2,677 01-20-2026, 01:43 PM
Last Post: Anna
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 4 9,162 12-11-2025, 08:57 AM
Last Post: jakfish
  Recycling pinephone as home server mdk 6 4,730 12-01-2025, 02:57 AM
Last Post: mdk
  PinePhone, PinePhone Pro, Keyboard/Accessories for sale brb78 5 3,727 11-30-2025, 05:45 AM
  Modem Issues with the Pinephone Temmie19 5 7,310 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 5,441 06-21-2025, 05:19 PM
Last Post: mikeb
  Pinephone not booting sd card... bruv 1 3,993 03-25-2025, 08:51 PM
