Hot when charging
do I answer y or N to Remove firmware?
entire message is as follows:
:: rtl8723bt-firmware-megi and rtl8723bt-firmware are in conflict. Remove rtl8723bt-firmware? [y/N]
(12-31-2020, 01:57 PM)ADGW Wrote: do I answer y or N to Remove firmware?
Yes
Well, I am happy to say that typing in y prompted the phone to finally do an upgrade. The phone still seems to be heating up. Not as bad as before, but still pretty warm. So I will not leave it alone while charging yet.
Thank you to everyone that helped. I need to start studying again. I used to be able to do a little on my own a few years ago. Forgot so much. Any suggestions on the best place to get some training? Where I used to go does not seem to exist and there are many more that I see online. Just wondering if there is a suggested one.
Again, Thank you for all the help. I might try to run through the update process again and see if anything else changes.
I would like to say a BIG Thank you to all that responded and helped.  After finally getting the new update and then restarting, I let the phone stay plugged in for quite a while and no more extreme heating or buzzing.
Thank you again and Happy New Year!
(12-31-2020, 11:25 AM)ADGW Wrote: Then it started to buzz.  I mean it almost sounded like a toy airplane buzz sound or something.  I thought that was strange so I turned it off and waited a couple of minutes.  No more buzzing.
Was the phone connected to a charger when this happened?
Yes, it was connected.  But I quickly disconnected and turned phone off.
Alright, in that case there's probably nothing serious to be afraid of.  You heard something resembling a sort of rapid clicks coming out of the phone, right?  I've also experienced the same behavior, and truth be told, it sounded quite weird, maybe even a bit scary. Smile
After some investigation, the cause of those weird sounds turned out to be rapid resets of the IC (ANX7688) that controls some of the functions of the phone's USB Type-C port.  The ANX7688 actually initiated the resets itself, as a result of (yet to be investigated) overcurrent protection. Each of those resets caused the plugged-in USB device (in this case, a charger or a powered dock) to be removed and attached again, at the logic level of course, which in turn caused the operating system to successively play back the sound that indicates an USB device plug-in event.
The above-described overcurrent protection is somewhat weird and remains to be investigated further.
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 3,201 04-02-2024, 11:50 AM
  WIRELESS CHARGING ADD-ON CASE Fred Zyphal 4 6,917 08-28-2022, 05:17 PM
Last Post: Fred Zyphal
  Charging the phone while it is off orbital 1 3,209 07-05-2022, 12:19 AM
  Mobile case wanted - with wireless charging! thorensjubilee 4 6,719 03-19-2022, 10:29 AM
Last Post: vap0rtranz
  docking bar limits charging rate? nelstomlinson 5 8,701 08-11-2021, 11:13 AM
Last Post: nelstomlinson
  battery and charging submariner 4 8,201 03-01-2021, 12:16 PM
Last Post: theD0ctor
  Plasma Mobile CE Pinephone - battery not fully charging PineSupporter 11 20,437 02-09-2021, 11:20 AM
Last Post: PineSupporter
  Latest PinePhone CE Manjaro - Charging issues: hardware or software? kern707 5 9,368 11-20-2020, 12:09 AM
Last Post: bcnaz
  Pinephone not charging and not powering up gab 10 22,341 04-20-2020, 08:53 AM
Last Post: Bates132
  PinePhone Not Charging. blicken 3 11,434 02-11-2020, 11:23 PM
Last Post: bcnaz
