Spare parts / keyboard
I'd like to convert my 1st batch ISO keyboard Pinebook Pro to an ANSI keyboard. However, the replacement keyboard has been out of stock for quite a while on the Pine Store. Does anyone know if these will ever re-appear?
(12-22-2020, 02:25 PM)mbreese Wrote: I'd like to convert my 1st batch ISO keyboard Pinebook Pro to an ANSI keyboard. However, the replacement keyboard has been out of stock for quite a while on the Pine Store. Does anyone know if these will ever re-appear?
Keep checking on their web site. As for the current date, January 6th, 2021 there's only the ISO model in stock.
https://pine64.com/product/pinebook-pro-...o-keyboard
Good luck. I was in the same situation, desperately searching for a spare, and after I finally got the ISO model I'm struggling right now to make it working properly. The difference between ISO and ANSI is not only about keys layout but also codes. It seems that I have to flash somehow a new firmware into it.
(01-06-2021, 02:35 PM)cmd Wrote: Good luck. I was in the same situation, desperately searching for a spare, and after I finally got the ISO model I'm struggling right now to make it working properly. The difference between ISO and ANSI is not only about keys layout but also codes. It seems that I have to flash somehow a new firmware into it.
Have you actually swapped the keyboards?
  pinephone keyboard oliveira11670 1 2,692 05-20-2026, 09:19 AM
Last Post: zetabeta
  Yet another new Pinebook keyboard problem MikoBob 3 5,805 09-11-2024, 07:05 AM
Last Post: MikoBob
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 239,854 09-13-2023, 03:43 AM
Last Post: k3dAR
  Separate ISO keyboard for PBP Besouro 0 3,061 06-04-2023, 02:51 PM
Last Post: Besouro
Information Keyboard Duplicate Keypress Fix RjraymondDuplicate 0 3,120 02-17-2022, 11:52 PM
Last Post: RjraymondDuplicate
  keyboard and usb ports not working User 24565 3 7,055 02-15-2022, 10:12 AM
  Replacing the Keyboard gabb 6 13,051 01-11-2022, 07:39 AM
Last Post: Valenoern
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 4,570 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  power on PBP if your keyboard is dead? stozi 0 3,546 11-29-2021, 01:55 PM
Last Post: stozi
  Replacement scissor switches (ANSI keyboard)? zackw 3 8,438 08-09-2021, 09:20 PM
