Raspberry 4 Charger for Pinephone?
I can't charge the Pinephone while it's powered on.
Finding a power supply with the specified values (15W (5V 3A) USB -PD) and USB-C is not that easy.
So how about the power supply of the Raspberry Pi 4? It comes with USB-C and 5.1V/3A.
Does that 0.1V really make a difference?
If you don't recommend it, could you point me to a different one?
I'm in Europe btw...
Thanks for your help!
(12-26-2020, 06:59 PM)jojuma Wrote: Hello,
I had the same problem as you, it was fixed by blacklisting the anx7688 module
echo "blacklist anx7688" >> /etc/modprobe.d/blacklist.conf
I use the Pi4's charger frequently with my Pinephone.  It works well. It also works well with the dock.
Megous recommends basic chargers using the Battery Charging spec as being more reliable than ones supporting Power Delivery. The BC ones will 'Just Work'™ while the PD ones need the right combination of ANX firmware and kernel driver support. Details here: https://xnux.eu/devices/feature/anx7688.html
(12-27-2020, 10:39 AM)wibble Wrote: Megous recommends basic chargers using the Battery Charging spec as being more reliable than ones supporting Power Delivery. The BC ones will 'Just Work'™ while the PD ones need the right combination of ANX firmware and kernel driver support. Details here: https://xnux.eu/devices/feature/anx7688.html
I've been using a generic 2A charger with no problems.
https://www.ebay.com/itm/US-Plug-5V-2A-U...1990531054
I'm afraid I'm not expert enough to understand that. What exactly does that blacklisting do and how does that solve the problem?
So I understand anx7688 is a driver handling the charging process. The description says:
Quote:In some configurations (with 3A USB-C PD charger) AXP803 resets the VBUS input current limit by itself to 500mA, so PP will not charge (much)
  • Forcing the input current limit back up leads to instability (looks like AXP is resetting the limit due to voltage drop on VBUS) and input current fluctuates between 0 and ~1.3A
Is there a way to check if that happened? And if so, it can't be fixed since fixing leads to instability? That means a problem, right?
Or am I wrong with this assumption?
(12-30-2020, 06:47 PM)jojuma Wrote:
(12-26-2020, 07:51 PM)evilbunny Wrote: echo "blacklist anx7688" >> /etc/modprobe.d/blacklist.conf
You need to open a terminal app and then you just type the above into it, you will most likely need to get root before running it, "sudo su -" will get you root access
I bought the power supply of Raspi4 but it charges only with 0,5A ;
now I use my power bank for charging with 1,5A.
That page is possibly a little outdated regarding state-of-the-art - see https://xnux.eu/log/#026 for an update. It can take a while for Megous' changes to make it either to the upstream kernel or the various distros though. You should be able to get some idea what's happening on your phone using:
cat /sys/class/power_supply/axp*/uevent
  Pinephone + Keyboard for sale, little use ruemoo 17 12,948 08-04-2026, 06:27 PM
Last Post: greebleshaver
  Pinephone - broken power button rorus 14 24,518 05-17-2026, 03:52 PM
Last Post: EuvzO8
  PinePhone 16 GB – Free to a Good Home Anna 2 1,892 01-20-2026, 01:43 PM
Last Post: Anna
Bug PinePhone modem keeps "disappearing" Kevin Kofler 17 20,765 12-12-2025, 03:27 AM
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 4 8,215 12-11-2025, 08:57 AM
Last Post: jakfish
  Recycling pinephone as home server mdk 6 3,522 12-01-2025, 02:57 AM
Last Post: mdk
  PinePhone, PinePhone Pro, Keyboard/Accessories for sale brb78 5 2,730 11-30-2025, 05:45 AM
  Modem Issues with the Pinephone Temmie19 5 6,198 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 4,478 06-21-2025, 05:19 PM
Last Post: mikeb
  Pinephone not booting sd card... bruv 1 3,295 03-25-2025, 08:51 PM
