PineTab Mobian
Does Mobian contain any proprietary software (including firmware/blobs)?
How can I remove the mobile phone apps such as calls and SMS from Mobian on my tablet?
(12-05-2020, 05:05 PM)a-wai Wrote:
(11-27-2020, 08:07 AM)Baslow Wrote: I'm not a developer, so I'm not sure if this makes a difference but internal BT doesn't work. My BT dongle does work.
Yes, this was a device tree issue, as the internal wifi wasn't properly declared, "generic" BT functionality always worked fine.
(note the use of "was" in the above sentence Wink )
a-wai - I can confirm, I just updated and rebooted. It came up and showed the built in bluetooth, I have connected a bluetooth mouse to it and it is working fine. This coupled with some performance improvement, it is making good progress, thanks for all the hard work!
Hello!
I'm using the Pinetab with Mobian ad I would like to thank the developers for the effort.
I have a pinetab without the keyboard option and I'm using it with a USB Keyboard case by HAMA (https://de.hama.com/00182501/hama-tablet...up-to-105-).
It's working fine but when I resume from suspend it's not powered and will not work until disconnecting and reconnecting.
Is there a way to make it persistent (keep the power to it) or to run a script to logically reconnect it after resume?
Latest status update (with some PineTab-related news too): https://forum.pine64.org/showthread.php?tid=12511
(12-08-2020, 11:35 AM)captainmorgan Wrote: How can I remove the mobile phone apps such as calls and SMS from Mobian on my tablet?
You can use the Software app to uninstall them like any other package.
Thank you!
(12-08-2020, 11:35 AM)captainmorgan Wrote: Does Mobian contain any proprietary software (including firmware/blobs)?
Maybe read this first:
https://www.pine64.org/2020/01/24/settin...nceptions/
If there any questions left, I guess only a developer can answer that finally. Overall I feel "safe" with mobian.
Hi everyone, I just started testing my PineTab. The first thing I noticed was that UBPorts development was stopped. So I reached for the Mobian, It works so much better but I have a question where is the terminal ???
(12-18-2020, 02:59 PM)Takaszi Wrote: Hi everyone, I just started testing my PineTab. The first thing I noticed was that UBPorts development was stopped. So I reached for the Mobian, It works so much better but I have a question where is the terminal ???
Its the "kings cross", the round red icon with the blue line
Oh thanks, I felt a little more like home. My adventure with Linux started 3 months ago. I do not know much and I have a lot of questions, for example how to install MC, RealVNC client, so far. I will try not to tire you.
  New Pinetab- error when attempting to install updates authorjaw 1 1,207 02-26-2026, 01:21 AM
Last Post: Raik
  Mobian OS stefan_hdb 1 3,094 04-08-2025, 09:14 AM
  PineTab (early adopters) wifi broken in kernel 6.12 bartgrefte 0 2,110 03-23-2025, 05:25 AM
Last Post: bartgrefte
  Where to find older Mobian image? guenther 2 2,944 10-30-2024, 02:50 AM
Last Post: guenther
  PineTab 2 login screen rotation fix chzbacon 11 17,858 03-17-2024, 04:53 PM
Last Post: mtomaschett
  NixOS on PineTab 2 asonix 3 7,809 02-24-2024, 12:29 PM
Last Post: Evergreen
  [PineTab2] Issues with Mobian Networking Cornelia Xaos 7 10,553 12-30-2023, 10:02 PM
Last Post: Cornelia Xaos
  Mobian Boot Problem rogerwegmann 14 16,556 12-13-2023, 11:04 AM
Last Post: diederik
  Working OS on pinetab RISC-V? user641 3 4,946 12-13-2023, 08:11 AM
  Mobian won't boot after ton of updates bartgrefte 11 15,654 12-10-2023, 02:47 AM
