Can the PineTab work without the battery?
I plan to use the tablet connected to the AC and powered on 24/7. Usually that's bad for the battery. Does this device work if i unplug the battery and only power it from AC? (Usually tablets don't power on without a battery connected)
Probably worth testing, I don't think anything bad should happen - I think your worst case is that it simply doesn't work.
If you do unplug the battery and plan to keep it this way, I would remove the battery entirely. 24/7 hard use could heat the battery considerably and still cause it to become damaged.
The problem is that i didn't order the tablet yet so i can't try to use it without battery (sold out) Smile
(11-30-2020, 12:24 PM)Luattoli Wrote: I plan to use the tablet connected to the AC and powered on 24/7. Usually that's bad for the battery. Does this device work if i unplug the battery and only power it from AC? (Usually tablets don't power on without a battery connected)
PineTab can work without battery installed.
  Not able to power on PineTab anymore zkajdan 4 5,940 01-12-2025, 10:38 PM
Last Post: vatin
  Battery discharges completely while the Tab2 is powered off between less than 24hs nonic 4 5,395 09-21-2024, 02:40 PM
Last Post: 459below
  USB hubs that work? draco_mike 1 3,033 01-03-2024, 11:05 AM
Question Will Pinetab 2 spare parts be available? vatin 6 8,792 12-09-2023, 01:31 AM
  ?brighter screen replacement for pinetab (>1600 nits) dynobang 0 3,317 09-28-2023, 01:06 PM
Last Post: dynobang
  [Tutorial] How to overclock Pinetab 2 Darth-Apple 0 4,327 09-25-2023, 08:45 AM
Last Post: Darth-Apple
  External Reset button on PineTab V? michaelengel 0 2,941 09-18-2023, 06:31 AM
Last Post: michaelengel
  Battery mshelby 2 4,148 08-22-2023, 08:22 AM
Last Post: alpopa
  Pinetab 2 screen no longer coming on Fibonacci 9 13,466 06-30-2023, 08:26 AM
Last Post: Purple_Illusion
  Pinetab completely bricked Saksmito 8 10,468 06-10-2023, 04:23 PM
Last Post: fxc
