Cant sign in after update
sudo pacman -Syu to update. After update pin no longer works. Permanently logged out. Guess I'll need to reflash...
Make sure you carefully read the terminal screen to check whether there were any errors during update.
In case you didn't reboot yet, you might want to try that first before reflashing.
There is a known bug in Phosh that will redirect you to the login screen right after logging in using the correct pin.
In that case, hold the power button for 20 seconds, and then boot up again.
I had the same problem, a reboot solved it for me.
  Using too much juice since last update Eugo 20 23,206 03-15-2024, 10:09 AM
Last Post: Eugo
  recent update Uturn 14 14,635 02-13-2024, 01:19 AM
  Latest update Eugo 21 25,490 03-09-2023, 05:27 AM
Last Post: Eugo
  Firefox issue with latest update Barugon 6 8,729 01-28-2023, 01:29 AM
Last Post: alaraajavamma
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 55,405 07-28-2022, 12:40 PM
Last Post: johaennessen
  How to disable automatic update checks bdicewk 4 6,895 06-12-2022, 08:10 AM
Last Post: bdicewk
  Locked out after update bnbcwllc 2 4,627 06-08-2022, 04:46 AM
Last Post: bnbcwllc
  Keyboard case stopped working on pacman update rotwang 5 8,268 05-07-2022, 09:17 PM
Last Post: rotwang
  Pinephone stuck on 'something went wrong' after update gofishus 1 4,046 03-06-2022, 05:48 PM
Last Post: fxc
  Lockup during update, force shut down and try again? tgz 5 11,250 12-22-2021, 03:11 PM
Last Post: tk1107
