slarm64 (unofficial slackware) Rock64 RK3328 (aarch64)
#91
(11-23-2020, 02:12 AM)Enig123 Wrote: Thank you for your quick help. BTW, I am using the base image, and the slackpkg installed from the current branch does not work as expected somehow. It kept asking for the correct pgp key.
Perhaps I installed the wrong version of slackpkg?
Edit: Another question is for how to unzip a .zip file, which usually use package named "unzip" in most Linux distributions.
in the file /etc/slackpkg/slackpkg.conf change CHECKGPG=on to CHECKGPG=off
unzip is in the package infozip-6.0-aarch64-5.txz
donation   irradium
Further help needed please. When I was trying to compile some c program, the following error message appears:
/usr/libexec/gcc/aarch64-slackware-linux/10.2.0/cc1: error while loading shared libraries: libisl.so.23: cannot open shared object file: No such file or directory
How can I do to fix it? I've already installed both 'd' and 'l' categories.
Edit: Even if I resolved this error by adding link to /usr/lib64/libisl.so.22.0.1, there's other similar errors coming, like libzstd.so.1, there must be something wrong with my development setup.
(11-23-2020, 02:42 PM)Enig123 Wrote: Further help needed please. When I was trying to compile some c program, the following error message appears:
the library is in l isl-0.23-aarch64-1.txz
it looks like not all packages are new.
try to do
slackpkg update slackpkg upgrade-all
donation   irradium
Tried it but with no success, unfortunately. The upgrade-all didn't do anything at all.
Edit: Other troubles that I've encountered, which also related to lib not found:
case 1: nslookup: error while loading shared libraries: libedit.so.0: cannot open shared object file: No such file or directory
case 2: dig: error while loading shared libraries: libjson-c.so.5: cannot open shared object file: No such file or directory
this is a bit weird when using the image.
what image did you use.
yeah, you installed bind separately, so you also need to install the library data.
donation   irradium
(11-23-2020, 04:24 PM)mara Wrote: this is a bit weird when using the image.
The image I am using is kernel 4.4.241 base.
As I recall, I didn't install bind separately, the nslookup command is already there.
And, which library data is needed for nslookup to work?
Edit: Right now, to fix the development environment is more urgent for me.
Edit1: Just tested nslookup with the 4.9.y base image, the same error message appeared.
libedit-20191231_3.1-aarch64-1.txz
json-c-0.15_20200726-aarch64-1.txz
added packages required for bind
donation   irradium
update:
slarm64-current-aarch64-base-rootfs-20201115-4.4.246-rock64-build-20201124.img.zst
slarm64-current-aarch64-base-rootfs-20201115-4.4.246-rock64-build-20201124.img.zst.sha256
slarm64-current-aarch64-xfce-rootfs-20201115-4.4.246-rock64-build-20201124.img.zst
slarm64-current-aarch64-xfce-rootfs-20201115-4.4.246-rock64-build-20201124.img.zst.sha256
@Enig123,
in this image I added missing libraries to nslookup.
donation   irradium
(11-24-2020, 03:44 PM)mara Wrote: update:
@Enig123,
Thanks.
Do I have to do it from scratch or is there a way to upgrade from last version?
And, how about the development setup issue?
Edit: Well, I just tried another time to setup development environment with the new image. It's not there yet.
Not only gcc has the same shared libraries (libisl.so.23 for example) error, git also has similar error, while it showed to be libnghttp2.so.14 instead.
I will be very appreciated if you guys can fix these errors and make this already great distribution even ready-er.
(11-24-2020, 04:46 PM)Enig123 Wrote: Do I have to do it from scratch or is there a way to upgrade from last version?
using a new image, yes.
install
l/isl-0.23-aarch64-1.txz
n/nghttp2-1.41.0-aarch64-1.txz
these are not distribution errors, this is dependency management, which in this distribution lies on the shoulders of the user.
donation   irradium
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 21,982 09-27-2026, 11:55 AM
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 5,455 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 99,280 07-22-2026, 01:47 PM
Last Post: MichaIng
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 2,228 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,851 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,857 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 4,119 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,328 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 5,186 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 119,586 09-01-2024, 06:05 AM
Last Post: RaymondDay
