New OS for RockPro64 is here, TwisterOS Armbian
Since I don't have a PinebookPro to fix it, I'm contacting someone from the team who has one. Just found out from another person who managed to get audio working on PInebookPro w/ Armbian-Reforged:
"To fix No audio issue with PinebookPro, we had it set in asound.state for our image. All good now"
I'll get details how to get his done step by step later on.
Good, thanks, but I am running it on RockPro64. Cannot try on Pinebook Pro, cause my SD card reader is broken.
Btw, is it not recommended to upgrade? I made a dist-upgrade and seems that Steam stopped working. Also, how do I start BOX86 and some games? I found some box86-update, but still unable to run box86.
(11-19-2020, 06:23 AM)jtremblant Wrote: Since I don't have a PinebookPro to fix it, I'm contacting someone from the team who has one. Just found out from another person who managed to get audio working on PInebookPro w/ Armbian-Reforged:
Thanks on the outstanding task and Armbian always create quality build. Please PM me your shipping address, email address and phone number (for shipping purpose), I will ship one Pinebook Pro to you.
Update (11-22-20)
To fix Redream - Dreamcast emulator audio sound issue:
sudo apt install libasound2-plugins:armhf
If someone needs to use Etcher on Armbian-Reforged, a PineBook Pro - Debian Stretch armhf version works just fine:
https://github.com/futurejones/balena-et.../releases/
balena-etcher-electron_1.5.63_Debian_Stretch_armhf.deb
-Next version will include a compiled arm64 Etcher version for it.
(11-19-2020, 06:42 AM)Wizzard Wrote: Good, thanks, but I am running it on RockPro64. Cannot try on Pinebook Pro, cause my SD card reader is broken.
You can upgrade without problems.  Until we are able to fully cover all RK3399 boards, support will just keep getting better. Currently working and heavily tested on RockPi4B and RockPi4C boards because that's what most of us have besides one NanoPiM4 and Orange Pi 4. RockPro64 will also get better supported soon as currently only one person from the team has the board. Same for PineBookPro. Help is on its way!
Steam App is an armhf version and still a WIP but getting worked on, an ARM64 Steam version is in the works with better support for BOX86. It'll be included in next Armbian-Reforged V1.1.
Box86 will run within the OpenGL games included with Armbian-Reforged. You can access them from the menu. We will have some videos to share with Box86 functionality.
We are trying to cover many things but will take some time to fix/upgrade/improve them as we go. Thanks for your patience.
(11-19-2020, 04:53 AM)Wizzard Wrote: I had the issue with sound at all, nither via HDMI, nor via audio jack.
Make sure to have sound settings as follows:
[Image: qvl2ty.jpg]
Update 11-23-20: A huge update and a major rework to Armbian-Reforged OS is in the works. Expect new great features and visual improvements as well on upcoming Armbian-Reforged version. General Performance as a Linux Desktop OS is getting improved too. Prepare to be Amazed. Stay tuned.
RK3399 performance on custom PPSSPP with PANFROST MESA driver (Armbian Reforged V1.0)
https://www.youtube.com/watch?v=dKULVvGSQD8&t=152s
(11-17-2020, 07:04 AM)jtremblant Wrote: ...
After booting for the first time, resize partition on uSD or eMMC with included gnome-disks utility.
Exciting times, thank you.
But ... I flashed to SDcard for a trial - booted fine to Mate desktop but won't recognise my (USB) keyboard/mouse so I cannot drive anything Sad
(Didn't seem to initialise my NVMe - led on NVMe didn't come on - but that would be a secondary problem.)
@dukla2000
I don't have a PineBookPro or RockPro64 but image by default is set to RockPi4C. It sounds like you're using the wrong dtb file.
I did successfully test it booting from NVMe on RockPi4C only.
Please follow the instructions below:
- edit /boot/armbianEnv.txt
- replace the dtb name with rk3399-pinebook-pro.dtb or whatever RK3399 board you have, check dtb folder to know the exact name you need to type.
- Enjoy
Don't forget to resize partition after first boot
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 13 23,041 09-27-2026, 11:42 AM
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 3,429 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  yocto for RockPro64 Fide 1 5,266 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 10,380 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 44,979 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 132,053 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 4,912 05-21-2023, 11:34 PM
Last Post: shpark
  Rockpro64 Dead on arrival? quixoticgeek 1 4,359 03-12-2023, 06:55 PM
Last Post: quixoticgeek
  RockPro64 boot questions misterc 3 6,947 01-13-2023, 06:21 PM
Last Post: misterc
  A fix for Bluetooth audio stuttering on the RockPro64 raph 2 5,289 01-03-2023, 06:53 PM
Last Post: raph
