10-13-2020, 07:32 PM
Hmm. Wonder if foss will work.
Sent from my OnePlus 7 Pro using Tapatalk
Google on Android?
11-15-2020, 03:21 PM
Ah, so if I understand correctly, if I can get Android to boot from SD card (haven't managed yet, but that's another topic), I can't actually use it to download an app from their Play Store? Bummer if that's true. Even though my Pinebook Pro is primarily my fun linux laptop (and a very nice on at that!) I thought it would be good to also be able to run Android to support a piece of hardware I use. But yeah, if that's not possible then I'd just have to get someones old Android tablet/phone and use that for that single purpose.
11-15-2020, 03:42 PM
You can use Aurora Store, probably. I don't know if that runs on 7.x Android. I use it on my newer devices (don't tell Google!).
11-16-2020, 01:04 AM
Ah, I also was pointed to APKpure where the app is available too. In my case it is the Suunto App (for Suunto training watches). I suppose this should also work on the Android image for the PBP. Has anyone tried this?
11-17-2020, 11:33 PM
https://***.androidpolice.***/2020/07/25/install-play-store-guide.. I hope this reference will be useful for you
11-18-2020, 06:24 AM
(11-17-2020, 11:33 PM)Raniyah Wrote: https://***.androidpolice.***/2020/07/25/install-play-store-guide.. I hope this reference will be useful for youThank you Raniyah. Yeah I think apkmirror is related to them, another apk installation service (other than apkpure I mentioned earlier). I'm starting to understand how Android works and that you can basically install an .apk file right into android without any "store". Unless the installation requires several individual .apk files with dependencies, in which case it would still be doable but an installation manager could make things easier. In my case, I don't think I'd need that. The .apk file is readily available so I suppose it should just work. Software only available in the Google Play Store is typically the kind of software I'm not interested in anyway .That said, your response is appreciated as there sure may be others who would like to run Play Store applications. Cheers!
01-23-2021, 08:30 PM
Have you tried downloading stuff on a phone, then using an APK extractor, then FTP the APK where you want it and do the install? I saw an APK installer. I've only tried this in Android for 10 minutes or so, then back to Linux. You can put Google Play itself through an APK extractor and do that with it. Similar problems on a Kindle which is butchered Android so only some things work.
F-Droid is worth a try too. It's a network of FOSS stuff, has an installer similar to Google Play. (01-23-2021, 08:30 PM)ab1jx Wrote: Have you tried downloading stuff on a phone, then using an APK extractor, then FTP the APK where you want it and do the install? I saw an APK installer. I've only tried this in Android for 10 minutes or so, then back to Linux. You can put Google Play itself through an APK extractor and do that with it. Similar problems on a Kindle which is butchered Android so only some things work. I would avoid F'-roid for two major reasons. First is I am sure what they want to install is not on there as most people want things like banking applications, and those FOSS applications can usually be downloaded directly from the project websites, or their GIT repos. And second major reason to avoid F-Droid is they have jumped on the cancel culture/censorship bandwagon.
03-15-2021, 03:21 AM
(01-23-2021, 11:47 PM)KNERD Wrote:Thank you guys for the valuable advice, I have been looking for this information for a long time.(01-23-2021, 08:30 PM)ab1jx Wrote: Have you tried downloading stuff on a phone, then using an APK extractor, then FTP the APK where you want it and do the install? I saw an APK installer. I've only tried this in Android for 10 minutes or so, then back to Linux. You can put Google Play itself through an APK extractor and do that with it. Similar problems on a Kindle which is butchered Android so only some things work.
08-26-2021, 06:33 PM
(01-23-2021, 08:30 PM)ab1jx Wrote: Have you tried downloading stuff on a phone, then using an APK extractor, then FTP the APK where you want it and do the install? I saw an APK installer. I've only tried this in Android for 10 minutes or so, then back to Linux. You can put Google Play itself through an APK extractor and do that with it. Similar problems on a Kindle which is butchered Android so only some things work. I like this opinion. complete no frills. |
| No Android build working! | pin | 60 | 137,876 |
07-03-2021, 06:08 PM Last Post: justiceankomah |
| MD5 On Android | jaysistar | 0 | 4,841 |
03-14-2020, 08:38 AM Last Post: jaysistar |
| Arguments for android support | metcalsr | 20 | 49,260 |
02-08-2020, 12:12 PM Last Post: Idaho |
All android buillds on wiki for Microsd missing GPT? | TDC_PBP | 14 | 34,715 |
01-31-2020, 11:22 PM Last Post: tophneal |
| Any word about Android builds? | tophneal | 36 | 79,510 |
01-26-2020, 12:06 AM Last Post: Account |
| Flashing Updated U-Boot on Android | tophneal | 6 | 16,948 |
01-16-2020, 06:05 AM Last Post: tophneal |
