PinePhone already setup?
I just received my PinePhone and I'm very excited to try it out! But after removing the tap between the battery and connector and booting up for the first time, I was taken to a lock screen. Swiping up takes me to a screen for entering a passcode. I was not taken through a first-run setup to create a user and I don't know what passcode I'm supposed to use.
Did I miss some communication about the phones being preset up and having a default code or do I need to reset the phone somehow? If so, any advice on how to do that would be appreciated.
The default Pin for Manjaro is: 1 2 3 4 5 6
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
@bcnaz Thanks alot!
Hi, I had a similar experience -
 after it started up did the navigation buttons appear or did you have to update or do something to get them to appear?
(02-27-2021, 10:27 PM)DonF22 Wrote: Hi, I had a similar experience -
I have just got my Pinephone Beta Edition and it has taken me through creation of user etc.  Now it asks for a PIN and 123456 does not work.  How do I progress?
Chris
I can now answer my own question...
On initial boot, I am asked to create a user with a password.  I did just that.  It then wouldn't let me continue until I entered a PIN.  It was only when I booted from an SD card image and repeated the process that I realised that Password and PIN were the same thing and that I should only have entered digits (numbers) originally (yes. It does tell you first time around).  Since my password happened to contain numbers I could unlock by just entering those.
Now happily playing
Chris
  PinePhone Game Thread PixelPaintbrush 31 80,129 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 22,220 03-25-2026, 12:55 PM
Last Post: baptx
  Pinephone visibly losing power while plugged in Hiraghm 8 6,922 03-09-2026, 07:51 PM
Last Post: Tia Vaughan
  pinephone-support package not upgradable on Mobian fhireman 5 7,121 02-28-2026, 05:49 PM
Last Post: baptx
  best setup to run waydroid with discord + instagram dustfinger 0 832 02-01-2026, 01:41 PM
Last Post: dustfinger
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 961 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 4,198 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 1,746 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 1,350 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 6,774 10-21-2025, 12:12 PM
Last Post: Richy_T
