4 Uarts and 2 Ethernet possiblities
(04-05-2019, 08:54 AM)martinayotte Wrote:
(04-04-2019, 08:17 PM)gops Wrote: Thank you, Is one UART design followed due to Raspberry PI compatible pins?
As many RPI2 styled interfaces provides 1 or 2 UARTs.
Non necessarily ... There is a second UART, the UART4 available on pins 19/21, but it is shared with SPI pins.
It is better to use those SPI pins for attaching the SC16IS752 chips ...
Hi, I just obtained my first Rock64, may i know how to enable SPI pin with SC16IS752 step by step in Linux?
TQ
You will need to compile your own kernel since most of them don't provide SC16IS752.
You will also need to add device tree SC16IS752 node inside SPI node.
(04-05-2019, 09:58 AM)LMM Wrote:
(04-04-2019, 12:20 PM)gops Wrote: 2. 2 ethernet(s) [100 Mbps is fine], one natively available, what is the best option to add second one?
Concerning a second NIC, I use a USB 3 Gigabit Ethernet adapter, it works quite well. To configure it, one needs to add a yaml file in /etc/netplan (in ubuntu)
LMM.
Hi LMM, sorry to resume an old post Smile What adapter do you use? I want to buy one for my Rock64 but I don't know if every USB3 to Ethernet adapter is the same or only some work with Rock64 (with Armbian in my case). Many thanks!
LMM.
Hi, I suppose that all are compatible. I use this one (french amazon - german store) :
https://www.amazon.fr/CSL-Adaptateur-Gig...B074TSY3BC
LMM.
  Rock64 board not working, no HDMI no Ethernet. EDited 3 11,371 01-17-2023, 02:31 PM
Last Post: Flagtrax
Tongue RockPro64 Ethernet NOP After Debian 11 Install... MattDralle 1 4,701 10-30-2021, 06:10 AM
Last Post: Rocklobster
  USB3 to Ethernet adapter giuseppe 0 3,336 11-11-2020, 05:48 PM
Last Post: giuseppe
  UARTs from GPIO headers maks.dav 1 4,576 10-27-2020, 12:06 PM
Last Post: martinayotte
  No green Ethernet LED sanis 2 7,089 03-06-2019, 11:21 PM
Last Post: sanis
  flash image to sd/emmc through ethernet LMM 0 3,965 02-04-2019, 07:36 AM
Last Post: LMM
  Rock64 ethernet problems ushills 4 9,760 05-29-2018, 05:16 PM
Last Post: pfeerick
  u-boot doesn't receive packets over ethernet hibernick 3 7,449 01-12-2018, 12:38 AM
Last Post: hibernick
  rock64 ethernet port sticker dkryder 1 5,348 11-14-2017, 10:18 PM
  Rock64 Ethernet LED Problem gaz2613 5 9,871 10-01-2017, 08:59 AM
Last Post: stuartiannaylor
