Just received Pinephone - system crashes
(11-06-2020, 09:15 PM)Zebulon Walton Wrote: I just ran the Postmarket OS factory test (V0.55.0 looks like the newest) from an SD card and fortunately everything tests out OK. That's a great tool for these phones! My first instinct when a computer locks up hard is to power cycle it, so I thought nothing of just pulling the battery. Any other hardware gotchas to be aware of?
Will have to play around with some more OS images to see if they're more stable than the factory-installed Manjaro. Will stick with SD card boot for now until something looks like it works well enough to flash to eMMC...
DO NOT pull the battery when the phone is on, even if it is locked up. Do a hard restart instead. It can corrupt the modem requiring reflashing the modem  firmware.
Mobian in my opinion is most functional and stable. Give it a little time and those improvements will reach the other builds.
I'll give Mobian a spin, though I do plan to try out several different distributions. Booting off the SD card makes it pretty easy, though a bit of a PITA to have to open the phone up and remove the battery to access the card. (I guess that's one way of making sure the filesystem on the SD card is not mounted when you take it out.)
I won't be removing the battery again with the unit powered on! As i said it's just that on most computers what we used to call "flipping the big red switch" is the normal thing to do with a system lockup. Maybe the phone should come with a warning slip in the package. I don't recall seeing anything about it in the small leaflet of instructions but the type is so small I may have missed it if there.
If diags are to be believed the modem survived OK but I do see in the wiki there is a procedure for recovering the modem firmware if need be.
To follow up on this, I finally got a chance to try out the Mobian 10-05-2020 release on an SD card and it is much, much more stable than the factory-installed Manjaro . The only time a system hang occurred with it was unplugging the Convergence Packate dock while the phone was running, and unlike the Manjaro crashes I was still able to shut it off using the power button. Other than that I played around with it quite a bit and installed some Debian packages. It basically ran well, though being alpha software of course there are still rough edges. I'll have to check out the nightly builds to see how it's coming along.
  Pinephone pro explorer edition systeamdos 0 2,488 03-31-2025, 03:35 PM
Last Post: systeamdos
  pinephone sales/availability jeremyrutman 5 11,537 07-15-2020, 05:38 PM
Last Post: bcnaz
  Emails from pine64 received as spam by gmail Matan 2 15,482 08-21-2019, 08:30 AM
Last Post: Leiaz
  No top system menu maxchess 3 8,462 06-14-2019, 07:11 AM
Last Post: maxchess
  qemu-system-aarch64 11b2p508 1 5,585 07-19-2018, 10:26 PM
Last Post: shizzle411
  Office System 24/7 donisonleague 2 6,444 07-04-2018, 06:22 PM
Last Post: donisonleague
  Robot Operating System (ROS) jesse1234 8 17,819 02-28-2017, 08:33 PM
Last Post: dkryder
  Reset system mcrognale 2 7,399 10-16-2016, 04:49 PM
Last Post: mcrognale
Sad Received two months ago still no good black screens matter 3 10,812 09-05-2016, 10:07 PM
Last Post: black screens matter
  Just Received my Order; It Doesn't work?! kikootwo 4 11,743 08-11-2016, 09:05 PM
Last Post: Mpoint
