qemu-system-aarch64
I have not received  a Rock64 board yet, I will be receiving a clusterboard probably sooner...
In the meantime, while awaiting the actual hardware, I have been trying to set up a dev environment, as well as emulators to test with.
In the longer term, too me, that is a better way to go rather than continually burning untested code to see if it works.
So, I pulled some images, been digging around, but really nothing current with Rock64 or Sopine emulation successfully (others, but have found none for the images in this sight)...
Has anyone using some of these images been successful loading these images in qemu-system-aarch, and booting them?
Seen talk, but even juggling around with the images, as well as command line switches to qemu. I have so far been unsuccessful.
Maybe I am missing something here.
Does anyone have anything to offer?
I'm hunting for the same solution. Did you end up finding one?
  StarPro64 Irradium (based on crux linux) riscv64, aarch64 mara 21 11,832 05-29-2026, 01:07 PM
  Star64 Irradium (based on crux linux) riscv64, aarch64 mara 19 17,676 05-12-2026, 08:17 AM
Last Post: tantamount
  Just received Pinephone - system crashes Zebulon Walton 12 22,682 11-13-2020, 05:45 PM
  No top system menu maxchess 3 7,915 06-14-2019, 07:11 AM
Last Post: maxchess
  Office System 24/7 donisonleague 2 6,001 07-04-2018, 06:22 PM
Last Post: donisonleague
  Robot Operating System (ROS) jesse1234 8 16,864 02-28-2017, 08:33 PM
Last Post: dkryder
  Reset system mcrognale 2 7,004 10-16-2016, 04:49 PM
Last Post: mcrognale
