Pine64 will not turn on
I followed the tutorial on the wiki to create a boot able sd-card with Phoenix card.  Put the card in the board and then plugged in a 1.5 amp power supply and nothing.  No screen output or no led on the board.
(05-03-2016, 02:54 PM)destroyer Wrote: no led on the board.
Then it's easy. Next step might be 'burning gone wrong' or 'fake/faulty SD card' or 'undervoltage and then crashing in early boot stage' or 'Ethernet connected on 1st boot when trying to use Android/RemixOS' or any of the other well known reasons why you could fail to boot this board. But if not even the led is lighting then it's simply no power at all (either caused by a DOA or by insufficient/broken PSU).
I have tried a couple of different sd cards. The power supply works fine I use it for other projects. Is 1.5 amps to small or should I get a bigger PSU?
If I plug in power to the board without a card inserted should the led turn on?
They recommend 2.0 amps or higher, but It worked for me with 1.2 amp LG charger from my nexus 5. It crashes if you connect something like usb hard drive, it doesn't crash with my 12 volt 2.1 amp Apple psu. Try different wire, different PSU if you have one, but most likely it's dead. It happens, I believe they will send you a new one.
Ok but shouldn't I at least get a light with no sd card installed when powered?
Yup, but it is possible that light is not working. So if you feeling optimistic you can keep trying, maybe try a different OS image.
  Having trouble reading MPU6050 sensor via I²C on Pine64 Jaxon 3 10,451 10-21-2025, 10:13 AM
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 3,784 08-24-2021, 08:17 AM
Last Post: lamson
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 7,157 06-17-2021, 05:35 AM
Last Post: kqlnut
  Just discovered Pine64 ! - first Q philip_rhoades 4 10,338 04-29-2020, 10:13 AM
  A newest user in Pine64 Aliko 1 6,657 04-19-2020, 10:33 PM
  PINE64 Installer - Simple Way to Image Your MicroSD pineadmin 101 216,918 01-15-2020, 12:46 PM
  Emails from pine64 received as spam by gmail Matan 2 15,235 08-21-2019, 08:30 AM
Last Post: Leiaz
  How to handle a Pine64 correctly gbjensen 6 23,187 03-28-2019, 11:43 PM
Last Post: InsideJob
Information Creating a NAS server in Pine64 javi_cala 4 12,548 01-21-2019, 02:03 AM
Last Post: bartes
  The 6 most common reasons why Pine64 won't boot Andrew2 109 308,554 10-11-2018, 11:35 PM
Last Post: Technolab88
