Install postgres
I've tried both the x86 and arm versions I found on the arch-linux wiki and they both gave me an error saying I do not have the correct architecture.  Where can I find a postgres that will work on PBP Manjaro?
Still confused about relationship btw Arch and Manjaro.
AArch64 is the right one.
(10-21-2020, 11:36 AM)Samurai_Crow Wrote: AArch64 is the right one.
I could use more explanation. I downloaded a file from here https://www.postgresql.org/download/linux/#generic
I ran it but then nothing happened but it seems installed. If I type psql it says the DB is not running and there is no UI from which to turn it off or. Are there instructions on how to install it? I can't find anything for arm.
So the way to do it I think, in the off chance anyone else needs this info, is to install it first then go the wiki and follow the instructions. I could not find a one-stop shop.
wiki: https://wiki.archlinux.org/index.php/PostgreSQL
arm: https://archlinuxarm.org/packages/arm/postgresql
ARM is 32-bit ARM. The PineBook Pro is 64-bit ARM which is called AArch64 architecture which isn't compatible with 32 bit Linux.
It installed though, without any errors saying that I was installing the wrong package type. I have failed during installation as it won't start the server, and I cannot delete postgres (to try a reinstall) as it requires a PW which I have not set/does not exist.
Doesn't seem like these would be related to wrong architecture though?
For the package manager?
id ,,, should show you are in sudo group
  Use SD to install new OS over pinebook debian Rudy558 10 27,265 03-09-2025, 11:17 AM
Last Post: davisthomas
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 6,903 08-03-2023, 03:30 PM
  Followed the blog post to install Fedora: PBP not booting anymore koenigs 6 6,857 06-01-2023, 10:58 AM
  MiniConda Install Issues nixyhustle 0 2,304 09-16-2022, 10:06 PM
Last Post: nixyhustle
  Does anyone know how to install levinsboot on pbp? computerc 0 1,892 09-05-2022, 03:52 PM
Last Post: computerc
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 4,566 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  microsoft teams install problem jip 3 7,267 02-17-2021, 09:27 AM
Last Post: pagesix1536
  Install TorBrowser on Pinebook pro 2020 edition BananaPekan 0 3,301 07-30-2020, 04:52 AM
Last Post: BananaPekan
  pip and install Jupyter lab jcj52436999 4 12,662 07-17-2020, 07:04 PM
Last Post: carlosqueso
  Need to install 64-bit Ubuntu rhyde 6 12,865 06-20-2020, 07:44 PM
Last Post: rhyde
