slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64)
#31
update:
update: slarm64-current-aarch64-base-rootfs-20200628-4.4.230-rockpro64-build-20200711.img.zst
slarm64-current-aarch64-base-rootfs-20200628-4.4.230-rockpro64-build-20200711.img.zst.md5
slarm64-current-aarch64-xfce-rootfs-20200628-4.4.230-rockpro64-build-20200711.img.zst
slarm64-current-aarch64-xfce-rootfs-20200628-4.4.230-rockpro64-build-20200711.img.zst.md5
donation   irradium
update:
donation   irradium
update: slarm64-current-aarch64-base-rootfs-20201003-5.8.15-rockpro64-build-20201014.img.zst
slarm64-current-aarch64-base-rootfs-20201003-5.8.15-rockpro64-build-20201014.img.zst.md5
slarm64-current-aarch64-xfce-rootfs-20201003-5.8.15-rockpro64-build-20201014.img.zst
slarm64-current-aarch64-xfce-rootfs-20201003-5.8.15-rockpro64-build-20201014.img.zst.md5
donation   irradium
I can't get this image to boot. It keeps hanging at
## Flatened Device Tree blob at 01f00000
  Booting using the fdt blob at 0x1f00000
Installed on SD card with:
zstdcat slarm64-current-aarch64-xfce-rootfs-20201003-5.8.15-rockpro64-build-20201014.img.zst > /dev/sdb
Both images have the same result. Is there a boot parameter I need to change for this?
Thanks.
(10-20-2020, 01:51 AM)janv Wrote: I can't get this image to boot. It keeps hanging at
Thanks.
I have on this image, when I turned on, I left the audio card in usb3, then the bootloader was overloaded.
And the bootloader in spi is old or new from this release, try to erase the spi bootloader.
donation   irradium
That worked Smile I appreciate your work. Do you accept donations in Bitcoin?
Thanks, so far only patreon.
One of these days I will collect the image on the kernel 5.9.y.
donation   irradium
update: slarm64-current-aarch64-base-rootfs-20201023-5.9.1-rockpro64-build-20201023.img.zst
slarm64-current-aarch64-base-rootfs-20201023-5.9.1-rockpro64-build-20201023.img.zst.md5
slarm64-current-aarch64-xfce-rootfs-20201023-5.9.1-rockpro64-build-20201023.img.zst
slarm64-current-aarch64-xfce-rootfs-20201023-5.9.1-rockpro64-build-20201023.img.zst.md5
donation   irradium
update: slarm64-current-aarch64-base-rockpro64-4.4.249-build-20210107.img.zst
slarm64-current-aarch64-base-rockpro64-4.4.249-build-20210107.img.zst.sha256
slarm64-current-aarch64-xfce-rockpro64-4.4.249-build-20210107.img.zst
slarm64-current-aarch64-xfce-rockpro64-4.4.249-build-20210107.img.zst.sha256
donation   irradium
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 13 23,040 09-27-2026, 11:42 AM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 183,806 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 3,429 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  RK3399 PCIe enumeration jhadd 0 3,516 01-31-2024, 08:56 AM
Last Post: jhadd
  yocto for RockPro64 Fide 1 5,266 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 10,380 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 44,979 08-16-2023, 01:34 AM
Last Post: varac
  How to enable CoreSight ETM trace on RockPro64 shpark 0 4,912 05-21-2023, 11:34 PM
Last Post: shpark
  rk3399 and Visual Output Processor 2 (VOP2) swan 3 7,854 05-13-2023, 12:01 AM
Last Post: swan
  Rockpro64 Dead on arrival? quixoticgeek 1 4,359 03-12-2023, 06:55 PM
Last Post: quixoticgeek
