Bluetooth microphone not detected
I'm on Manjaro and I recently got a set of bluetooth headphones with inbuilt mic (https://www.amazon.co.uk/gp/product/B07C5VW8D1/).
The bluetooth pairing works fine, and I can get audio output through the headphone speakers, but the microphone doesn't seem to be detected, and the "Recording devices" list on audio settings shows only "Analog Input (Built-in Audio Stereo)".
Any ideas?
Update:
On a cross-post at forum.manjaro.org, a member of the ARM team writes,
Quote:I seem to recall something about the wireless chip not being able to do WiFI and Bluetooth (microphone) at the same time. Don’t know if it’s true or not.
And I know we haven’t gotten the microphone part of the headset jack to work (if it’s indeed a dual jack).
Sounds like the problem might not have a solution.
I can confirm, that all my bluetooth audio devices on Manjaro ARM have only A2DP profile, which have only stereo output. On default "Debian" (in January, I think) bluetooth audio was barely working, switching to HSP/HFP profile was either crashing bluetooth or disconnecting, restarting bluetooth wasn't working either (only a bluetooth mouse was working back then). Also, my bluetooth speakers worked then in A2DP mode only with single speaker, pairing two speakers together (for stereo output) also was crashing bluetooth. I've kept original eMMC module with "Debian", but I cannot test bluetooth with it, because it was the last thing that stopped working and it was the main reason to ditch "Debian" on PBP.
But on the other hand, it wouldn't be the first time something isn't fully working on Manjaro, e.g. HDMI audio (or whole HDMI in case of mainline kernel), send SMS in KDE Connect, adding projects in BOINC Manager.
Do not let go. You need to test your headset with other distros and something else than PBP, check versions of packages related to bluetooth audio (from firmware to pulseaudio), use ArchLinux Wiki if you're not familiar with bluetooth on Linux.
Do not let go, because the only working microphone on PBP is the left built-in microphone. I don't believe in dual jack on this thing, the microphone in my wired headset was never working on PBP. The bluetooth headsets would be the only solution to recording audio on PBP with something better than the built-in microphone. Try to avoid 2,4GHz WiFi, use 5GHz WiFi or Ethernet to avoid interference.
OK, after last Manjaro update 20.10 (maybe, or maybe my headset was just acting weird last time), I have the ability to switch to the HFP/HSP profilie (the second time I've connected to the headset this profile was availaible in bluetoothctl info, in pactl list outputs and in the sound settings). I can hear that microphone is working, but I cannot record anything.
  NVMe drives not detected mattpenn 18 31,591 12-24-2024, 08:54 PM
Lightbulb Bluetooth headsets - what works? embhorn 17 38,817 03-22-2021, 11:45 PM
Last Post: ab1jx
  Microphone not working on Pinebook Pro vfr400racer 2 7,588 03-21-2021, 02:56 AM
Last Post: vfr400racer
  Anyone have a microphone working on a Pinebook Pro? Rachel Stone 5 9,799 02-20-2021, 05:21 AM
Last Post: dsimic
  Speakers not detected PineHead7 1 5,430 01-07-2021, 01:50 AM
Last Post: ab1jx
  Can't get wired headset microphone to work mjc 1 5,194 10-16-2020, 07:08 AM
Last Post: Arwen
  Soldering internal Wifi/Bluetooth antenna petet0n76 1 6,250 06-20-2020, 12:01 PM
  Still struggling with microphone input diodelass 0 3,931 06-15-2020, 05:49 PM
Last Post: diodelass
  Microphone not working linuxfreund 0 3,527 06-09-2020, 02:11 PM
Last Post: linuxfreund
  Microphone in through headphone jack SageFox 1 7,110 03-26-2020, 12:27 PM
Last Post: zaius
