Mainline U-Boot with SPI, NVMe and SATA boot support
#51
(09-18-2020, 01:33 PM)sigmaris Wrote:
(09-17-2020, 11:45 AM)jja2000 Wrote: So from what I can tell the HDMI patch for u-boot has been merged. Is hdmi actually working now @sigmaris ? How about the usb-keyboard driver? What would need to be done to get that working?
HDMI output and USB keyboard support are both enabled in mainline U-Boot.
Very cool, excuse me for asking, but do you know how to install that version? Is there a proper repo for me to download those from?
Hi sigmaris,
The builds on Azure seem to have expired - would it be possible for a new image to be created with the SPI installer and compressed image support?
(10-18-2020, 12:51 AM)voltagex Wrote: The builds on Azure seem to have expired - would it be possible for a new image to be created with the SPI installer and compressed image support?
I've pushed a new branch based on v2020.10, with a build here. There was some breakage of the SPI support in 2020.10 which I worked around by deleting the alias added in that commit. Treat this as a beta or pre-release - when ARM Trusted Firmware v2.4 is released next month, I'll make a proper tagged release including that.
Am I completely missing where the binaries are for this? You've skipped the GitHub release for that branch.
Additionally, is it possible to increase u-boot's debug level? It might help me solve an unrelated issue.
(10-18-2020, 07:56 PM)voltagex Wrote: Am I completely missing where the binaries are for this? You've skipped the GitHub release for that branch.
The binaries are published as build artefacts, attached to the build in Azure Pipelines - click on the "3 published" link on the build page I linked to before, to download them. As I said above, when v2.4 of ARM Trusted Firmware is released, I'll tag a Github release.
If you want a debug build, look at the build pipeline script (reference for the pipeline syntax) and other guides to building U-Boot from source, modify the source code to set the debugging/logging you want, and build it according to the same process.
used rockpro64 u-boot v2020.01-ci but it does not detect storage on usb 3.0. It does detect the JMS578 on usb 2.0 however, but so does literally every other uboot version I've ever flashed - aka this is nothing special.
I want the usb 3.0 port to work for 2 reasons:
1. it's faster transfer speed
2. it actually manages to power a spinning drive as opposed to usb2.0 which screws up and you have to unplug and replug to get a successful spin-up. No, it's not the damn power supply, I can do that with a 12V 1.5A lying around just as well as the 12V 3.5A. It's not lack of power, it's whatever the board instructs the controller to do, which is to cycle power repeatedly for some weird reason.
Here it is when I unplug and plug back in on usb 2.0:
Device NOT ready
  Request Sense returned 02 04 01
2 USB Device(s) found
scanning bus 1 for devices... 1 USB Device(s) found
scanning bus 2 for devices... 1 USB Device(s) found
scanning bus 3 for devices... 1 USB Device(s) found
      scanning usb for storage devices... 1 Storage Device(s) found
Device 0: Vendor: JMicron  Rev: 3102 Prod: Generic
            Type: Hard Disk
            Capacity: not available
... is now current device
Device NOT ready
            Type: Hard Disk
EHCI timed out on TD - token=0x80008d80
Ok there's some progress with U-Boot SPL 2020.10-07965-g0ce9b07852 (Oct 12 2020 - 21:45:42 +0000).
One of the coolest features: switched console output to video and I can actually use a keyboard to type commands to u-boot rather than time the plugging in of pin #10 just right so rockpro64 won't freak out on me and not boot.
Trying to boot from SPI NOTICE:  BL31: v2.3(release):v2.3-797-g7ad39818b NOTICE:  BL31: Built : 21:43:53, Oct 12 2020 U-Boot 2020.10-07965-g0ce9b07852 (Oct 12 2020 - 21:45:42 +0000)
It now seems to stop the usb2.0 power-cycle after 3x of them, disk gets detected and it tries to load stuff off of it. It doesn't actually boot, it gets stuck here:
Scanning usb 0:3... Found /extlinux/extlinux.conf Retrieving file: /extlinux/extlinux.conf 937 bytes read in 15 ms (60.5 KiB/s) select kernel 1: kernel-5.6.0-1137-ayufan-ge57f05e7bf8f 2: kernel-5.6.0-1137-ayufan-ge57f05e7bf8f-memtest Enter choice: 1: kernel-5.6.0-1137-ayufan-ge57f05e7bf8f Retrieving file: /initrd.img-5.6.0-1137-ayufan-ge57f05e7bf8f 21658962 bytes read in 556 ms (37.1 MiB/s) Retrieving file: /vmlinuz-5.6.0-1137-ayufan-ge57f05e7bf8f 22915584 bytes read in 553 ms (39.5 MiB/s) append: rw panic=10 init=/sbin/init coherent_pool=1M ethaddr=2e:68:c4:77:e9:11 eth1addr= serial=f671f593e6dba571 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 root=LABEL=linux-root rootwait rootfstype=ext4 Retrieving file: /dtbs/5.6.0-1137-ayufan-ge57f05e7bf8f/rockchip/rk3399-rockpro64.dtb 56725 bytes read in 21 ms (2.6 MiB/s) ## Flattened Device Tree blob at 01f00000   Booting using the fdt blob at 0x1f00000
On USB 3.0 there's still no device detection. For comparison:
USB 3.0: scanning bus usb@fe380000 for devices... 1 USB Device(s) found scanning bus usb@fe3a0000 for devices... 1 USB Device(s) found scanning bus usb@fe3c0000 for devices... 1 USB Device(s) found scanning bus usb@fe3e0000 for devices... 2 USB Device(s) found scanning bus dwc3 for devices... 1 USB Device(s) found        scanning usb for storage devices... 0 Storage Device(s) found USB 2.0: scanning bus usb@fe380000 for devices... 2 USB Device(s) found scanning bus usb@fe3a0000 for devices... 1 USB Device(s) found scanning bus usb@fe3c0000 for devices... 1 USB Device(s) found scanning bus usb@fe3e0000 for devices... 2 USB Device(s) found scanning bus dwc3 for devices... 1 USB Device(s) found       scanning usb for storage devices... 1 Storage Device(s) found
On U-Boot TPL 2020.10-07965-g0ce9b07852 (Oct 12 2020 - 21:45:42), if you issue "usb reset" U-boot will freeze. It does not respond to anything, the only option is to power cycle the sbc.
How to get ride of this problem?
Device 0: unknown device
failed to find ep-gpios property
I have the appropriate PCI-Express card (pcie to nvme) but get this error
Any help is welcome
Thanks in advance
  (real) Mainline U-boot finally works on SPI, boots SATA, throw away your SD cards NOW aleksei 0 12,985 06-21-2025, 06:21 AM
Last Post: aleksei
  How to use ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card jykeith123 1 5,535 11-26-2024, 11:08 AM
  enble boot after power loss/restore dkebler 18 30,603 12-04-2023, 12:14 PM
Last Post: ok38
Bug Broken boot: What am I missing? mkosarek 1 4,624 09-08-2023, 08:14 AM
  Unable to boot Armbian on new RockPro64 mooseball 5 13,981 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 14,274 05-18-2023, 10:46 AM
  u-boot locked on pine64pro ljones 1 4,675 09-06-2022, 10:32 AM
Last Post: ljones
  Cannot get my board to boot deutschlmao 11 20,147 09-05-2022, 04:23 PM
Last Post: ljones
  U-BOOT Tutorial hazz 0 3,617 07-19-2022, 10:48 PM
Last Post: hazz
  Installation Debian on emmc: which U-Boot and where? vongillus 3 8,144 07-02-2022, 09:24 AM
Last Post: dkebler
