Install OS directly to eMMC?
You should, of course, shrink the partition first if you have grown it to fill your SD card, otherwise you will almost certainly end up with corruption.
If it's possible to increase the pixel density of the screen I think it would be ideal since I think most phone apps probably would do better with 150% the current PPI density. Also, digitizer accuracy and responsiveness are pretty important and maybe having a faster form of memory than SD-Card.
Of course it depends on what kind of device you are trying to build and what cost-range too. I think there's interest in a more expensive higher quality device provided value is exchanged for the benefits.
  Difficulty with openSUSE Tumbleweed Install PinePhone Beta danm1988 0 1,388 11-17-2025, 07:49 AM
Last Post: danm1988
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 81,222 07-26-2024, 10:35 PM
Last Post: Peter Gamma
  changing from bullseye to bookworm to install mmsd-tng jyoung 8 9,978 04-09-2023, 06:08 PM
Last Post: zetabeta
  Install OS Permanently ismkdc 1 3,593 03-20-2023, 01:13 PM
Last Post: fxc
Question PinephonePro can't Flashing to the eMMC ricardo 0 2,134 08-21-2022, 05:51 AM
Last Post: ricardo
  install packages pamac anbox neithan76 0 2,057 07-18-2022, 07:13 AM
Last Post: neithan76
  How to replace the home folder on eMMC ragreenburg 2 4,562 03-31-2022, 02:19 PM
Last Post: ragreenburg
  Wipe out eMMC before flashing new OS? zkajdan 15 22,890 11-13-2021, 03:10 AM
Last Post: zetabeta
  Streamlined jmms install amindfv 1 3,667 10-29-2021, 07:04 AM
Last Post: TRS-80
  Anbox: install Google Services sonic 0 3,332 02-07-2021, 04:45 AM
Last Post: sonic
