With what image(s) does phoning fully work?
(09-23-2020, 03:44 PM)goku499 Wrote: Don't take it badly but are you aware that the Pinephone's software is still alpha? This isn't your usual ready to use phone.
He was informed many times. I helped him with 5 of his 7 issues. Anything short of exactly what he wants he attacks you and complains to everyone because he didn't do any research whatsoever.
Another forum member offered to buy his phone from him even. He likes to complain.
(10-02-2020, 11:50 AM)LazLong Wrote:
(10-02-2020, 07:53 AM)mattpenn Wrote:
(10-02-2020, 07:39 AM)LinAdmin2 Wrote:
(10-02-2020, 06:13 AM)mattpenn Wrote: Do any of the distros wake from sleep when calls are received? On both mobian and arch I have tested in bound calling when the phone is sleeping and it wakes to the point I can see the lockscreen but nothing further happens.
Don't worry - be happy Blush
(You must have known when buying that it does not work as real phone)
I read and accepted the Braveheart early adopters messaging the same as everyone else Smile
I'm just wondering if other distros happen to have this solved yet because:
* The multi boot image which would speed up my own research isn't available for Braveheart devices yet
* I'm experiencing calls breaking on my Sailfish OS running Sony XA2 so would very much like an option to migrate to the PinePhone as a daily driver
My BH's modem has been defunct since receipt and I have not been actively keeping up to date on megi's multi boot work so I could easily be missing something but I thought the 13 distro build was BH compatible.
Search with keywords with "Megous", "multi", and "Braveheart" yields following:
megous:
09-14-2020, 09:36 AM (This post was last modified: 09-14-2020, 09:54 AM by megous.)
Here's the updated image that also supports Braveheart: https://xnux.eu/p-boot-demo/
https://forum.pine64.org/showthread.php?...ight=multi
Hope this helps and good luck.
Thanks for this, installed and working on Braveheart. Smile
Should have searched but thought it was still in progress as downloaded the torrent (after the quote date here) and got the README with the note about Braveheart compatibility.
You again are plain wrong.
My valid point was and still is: pine64.org promised on the shop page that, although the software was preliminary, phoning, SMS and some other features would work.
Nobody - not even you - had at that time a solution to these problems!!
If you do not stop this kind of unfunded attacks I will find ways to stop you.
Does it dial and connect? Then it is capable and does make calls. Just because you don't think it's perfect doesn't mean it doesn't work.
1. I wasn't talking to you.
2. Are you threatening me?
  Should HDMI output work immediately? Richy_T 0 1,687 10-20-2025, 05:06 PM
Last Post: Richy_T
  Is it normal for the pinephone to "discharge" after fully charged on multiple OS? Shad190 2 3,819 05-10-2023, 10:37 PM
Last Post: Shad190
  UPDATED (June 2021): 17-distro multi-boot image for Pinephone (incl. 3GiB variant) megous 182 402,551 03-05-2023, 11:04 AM
Last Post: Eugo
  PureTalk work with Pinephone? car46999 6 10,054 01-30-2023, 12:05 AM
Last Post: car46999
  likely bug, volte does not work when operator side data blockage is activated zetabeta 1 3,404 05-21-2022, 03:03 PM
Last Post: zetabeta
  SD nonfunctional, how is support supposed to work? slomobile 6 9,507 01-18-2022, 07:02 PM
Last Post: slomobile
  Best OS where most of the things work? themagicm 13 20,579 12-09-2021, 07:28 PM
Last Post: ryo
Sad LTE data does not work on T-Mobile US with latest postmarketOS 21.06 SP3 PacificSinewave 1 3,848 11-07-2021, 10:15 AM
Last Post: beta-user
  Can't mount eMMC image on my desktop? nelstomlinson 0 2,734 10-16-2021, 09:30 AM
Last Post: nelstomlinson
  Lets discuss the GPS. Who has got it to work? AwHereWeGoAgain 8 13,533 09-17-2021, 01:29 PM
Last Post: KNERD
