Battery that drains even with the Pinphone turned off
So, what's the recommended way to shut down braveheart (1.1) at the moment? Is there a way to send the userspace shutdown to the modem manually and then power down pmos?
(09-26-2020, 04:33 PM)kuleszdl Wrote: So, what's the recommended way to shut down braveheart (1.1) at the moment? Is there a way to send the userspace shutdown to the modem manually and then power down pmos?
Have a try with "poweroff" in terminal?
(I cannot test myself because I do not have braveheart)
sudo poweroff sudo shutdown now
Or use the equivalent function built into the desktop environment. For example, phosh has a power menu in the top-right.
As mentioned earlier in the thread, do not remove the battery, or operate the modem killswitch, until the PinePhone has been powered down for 30 seconds.
I tried the mentioned actions, however, the system did not shut down properly (it didn't with the powerdown function in the menu, and poweroff in console did not help either).
Another follow-up question: If I disable the modem via killswitch, will I still face these battery drain issues? I'm using my BH pinephone just as a device for testing so I don't really need the modem. On the other side, I don't want to screw the battery...
  Battery life improvement freelectro 11 13,206 09-14-2026, 08:53 AM
Last Post: Juergen
  Battery connector dead mdk 5 5,439 01-15-2026, 02:24 PM
Last Post: mikeb
  Jumpdrive boots Computer(s) don't recognize PinPhone sfb 0 3,223 10-11-2024, 05:47 AM
Last Post: sfb
  Battery Life- hardware abstraction layer-GPU VS optomizing app for GPU-openGL biketool 1 4,001 09-20-2024, 04:04 AM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 5,415 02-17-2024, 04:15 PM
Last Post: vortex
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 5,623 03-20-2023, 12:54 AM
Last Post: bcoyle
  Power supply vs battery albafrati 11 13,960 06-22-2022, 06:04 PM
Last Post: albafrati
  What PD charger/dock combo results in PP battery not draining while using convergence james8880 0 3,887 04-28-2022, 12:45 PM
Last Post: james8880
  Battery mot charging past 54% StickyPine 32 53,581 02-26-2022, 02:07 AM
Last Post: vusra
  Battery replacement alternative sax1960 7 12,751 08-29-2021, 07:03 AM
Last Post: bcnaz
