My Pinebook Pro.
(09-26-2020, 12:38 AM)zer0sig Wrote: I'll have to look into that. I thought my PBP was noly partially sleeping, but I just realized that it stayed powered up for the last couple of days as it kept an IRC connection open. So it looks like it's not doing anything when I close the lid. I will check out the magnet location bit, though, thanks!
You can verify if yours is in the wrong place with a small magnet.  You should be able to reliably "sleep" the machine by placing the magnet somewhere to the right of the power and backspace keys.  (Sorry, I don't know the exact location offhand.) Then compare that to what the machine does with the lid closed.
I find (and several others have reported) that if the lid is open just a few degrees, the magnetic field lines up and the machine thinks the lid is closed.  Any more closed than that, and it thinks it's open.
Even easier, If NOT sleeping, display comes back instantly
If sleeping, a 2s pause, then mouse cursor, 4s pause, login screen
The external magnet is needed though to prove that the switch is working as intended. Else the magnet position might not be the culprit.
  PinePhone BE & Pinebook Pro shipping update thread Luke 136 289,191 06-04-2021, 09:43 AM
Last Post: Luke
  Next round of Pinebook Pro pre-orders Luke 10 34,223 12-19-2020, 07:58 AM
Last Post: fwav
Information August/ September Pinebook Pro, PineTab and PinePhone shipping thread Luke 256 611,102 10-27-2020, 11:14 AM
Last Post: Luke
  Pine Store: ANSI Pinebook Pro Available bcnaz 2 8,503 08-30-2020, 02:56 PM
Last Post: Luke
  Pinebook Pro & PinePhone shipping progress (2020) Luke 659 1,562,078 08-07-2020, 05:38 AM
Last Post: Luke
Heart Pinebook Pro ANSI preordering KC9UDX 2 8,023 07-21-2020, 04:00 PM
Last Post: Luke
  Pinebook Pro pre-order ANSI & ISO now live Luke 19 44,765 04-30-2020, 09:16 AM
Last Post: Surehand53
  November Blog Update -- PinePhone Braveheart, Pinebook Pros, and a giant Pine Cluster fire219 10 30,500 11-17-2019, 10:28 PM
Last Post: billydun
Information More Pinebook Pro pre-oders now available Luke 11 29,455 11-04-2019, 06:43 PM
Last Post: Luke
  Pinebook Pro subforum is now live! fire219 41 93,149 11-03-2019, 04:57 AM
Last Post: Greendan
