eMMC won't flash
Received my PinePhone earlier this week.
I flashed mobian onto the eMMC last night. This morning, the phone had a solid green light, and would not boot. The LED stays green and would not boot.
Found the test*.img, and ran it.
Everything passes, except the "Flash to eMMC".
not sure what to do at this point. Any other ideas?
(09-12-2020, 12:34 PM)RodMyers Wrote: Received my PinePhone earlier this week.
Flash an SDcard and check all is well.
How did you flash eMMC? I use, and would recommend, Jumpdrive.
My bad.
Yes, jumpdrive and dd onto the eMMC.
Funny thing. I removed the battery, fired up the windows laptop, used etcher to finally re-flash the phone.
No idea what was going on this day, but everything now works
My bad.
I have read similar reports every so often. Seems to be a slightly bad flash which is fixed with a reflash.
I wouldn't worry about it unless it continues to happen. If it happens again, redownload your image (could be a dl error, did you verify the checksum?) and see. If it happens after all that, it's likely an emmc issue.
  emmc speed via usb? joe1 0 3,202 04-27-2024, 08:07 PM
Last Post: joe1
  eMMC upgrade EuvzO8 5 7,420 11-08-2023, 11:58 PM
Last Post: brken
  [Megapixels] Flash strobe, pictures viewer and MPCamera error 22 freelectro 3 5,697 03-27-2023, 03:27 AM
Last Post: freelectro
  RAM corruption, possible eMMC corruption alnyan 3 5,891 08-24-2022, 03:07 AM
Last Post: JeremyWadsworth
  Emmc yvan 1 3,590 07-07-2022, 08:16 AM
Last Post: Chief
  Any experiences with hardware mod to improve eMMC speeds? kqlnut 9 13,842 04-19-2022, 02:36 PM
Last Post: kk22
  Where is the Pinephone eMMc? tgz 12 22,147 02-10-2021, 06:24 PM
Last Post: dsimic
  New motherboard - ANX firmware won't flash. --- 17 26,280 12-26-2020, 01:53 PM
Last Post: p1x3l3d
  Pine phone eMMC read speeds ? bcnaz 14 27,050 11-20-2020, 02:52 AM
Last Post: LinAdmin2
  broken emmc nieral 7 15,094 08-26-2020, 09:24 AM
Last Post: nieral
