I can't put the sim card in the slot
I tried several ways to put the sim card in the l lower slot.
First, I pushed it all the way in and as a result the card almost completely disappeared in the slot, but the phone didn't recognise it. It was very difficult to take it out, I had to use a needle to force it out. It took me quite some time to take it out. I am afraid I damage the simcard.
What is the proper way of putting the simcard in the slot?
Thanks a lot.
Are you using an adapter?
(09-11-2020, 05:50 AM)josekar Wrote: Are you using an adapter?
No, I don't have any adapter. I just took the sim card out of my android phone and I try to put it in the  pinephone as it is.
Should I buy an adapter?
Where can I buy one?
Can anyone confirm, is this the  right sim card adapter for pinephone?
https://www.amazon.ca/Neuftech-Sim-Card-...188&sr=8-6
Yeah, that'll work.  You should just need the yellow one (nano to micro)
(09-11-2020, 11:24 AM)neil_swann80 Wrote: Yeah, that'll work.  You should just need the yellow one (nano to micro)
Thanks, I ordered it.
My recent PMOS Pine phone came with the sim adapter.
It is easy to miss, it is taped with clear tape to the inside of the phone package.
Extremely little.
Extremely little.
+1 my UBPorts came with 2 different ones that each had a different fit (both for the same size sim)
  Pinephone not booting sd card... bruv 1 3,914 03-25-2025, 08:51 PM
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 27 46,760 01-29-2023, 12:20 PM
Last Post: skandigraun
  Pinephone won't boot from SD card arkadione 3 8,415 05-25-2022, 03:26 PM
Last Post: sfb
  Largest supported micro SD card? zooidic 2 4,979 01-08-2022, 06:01 AM
Last Post: zooidic
  Red LED when trying to boot from SD card. Need advice. サーバント 5 10,200 10-20-2021, 09:40 AM
  Fragile SIM card connector hakkou 1 3,903 08-25-2021, 07:44 AM
Last Post: wibble
  [Help] SIM slot contact broken WinstonSmith 3 8,325 07-14-2021, 06:13 AM
Last Post: mouffa
  Sd card slot death? Hurrikan 7 13,121 05-17-2021, 03:55 PM
Last Post: jrballesteros05
  WARNING to future users ~ Order yourself a SIM Card Extender Bonesdog 3 7,513 05-03-2021, 10:06 AM
Last Post: Bonesdog
  Strange SD Card Problems anhilde 7 13,171 02-21-2021, 07:52 AM
