Pinephone battery issue
Bug
There is some weird battery issue with this pinecone. Battery level dropped from 88% to 26% in 5 minutes. Feeling the battery temperature with the left hand with the cover off and navigating apps on the phone ( reproduced both with Ubuntu touch and Postmarket OS ) I am feeling the battery getting very hot then dropping back to room temperature as I am navigating apps on the phone. When the battery gets hot, the battery indicator level is visually decrementing percentages as I am looking at the display.
Any other users experiencing this issue?
What model do you have? Braveheart, UBports or postmarketOS Community Edition?
The battery indicator, especially on Ubuntu Touch, is inaccurate. Regardless, the heat described is abnormal.
A couple of things to try:
If the heat issue persists, report back and consider contacting Support.
(09-04-2020, 10:37 AM)jed Wrote: What model do you have? Braveheart, UBports or postmarketOS Community Edition?
Hello. The phone is the UBPorts edition.
The same here with a PostmarketOS version.
Has you solved the problem?
Many thanks in advance.
T.
I have received the Postmarket OS convergence edition 2 weeks ago, and the same battery issue as described occurs,
the phone does not hold on the battery and discharge pretty quickly when using the phone
(meaning when the phone is not plugged to the charger).
@mactoni @Jyv Is the heat issue also manifesting, or just poor battery performance?
If you are experiencing a heat issue like the OP, I'd recommend contacting Support. Otherwise, know that the PinePhone's battery life is short compared to other smartphones.
  need help whit pinephone janjansen1312 1 5,185 10-29-2025, 04:17 AM
Last Post: InFerNo
  PinePhone Keyboard update [April 24/04] Luke 73 188,314 08-12-2022, 11:46 AM
Last Post: kat22
  The PinePhone keyboard and cases are here! Luke 11 29,900 03-11-2022, 07:16 AM
Last Post: nontrivial
  PinePhone community poll results Luke 2 11,798 02-01-2022, 04:03 PM
Last Post: zer0sig
  PinePhone Pro Explorer Edition is now available Luke 1 10,788 01-12-2022, 11:52 AM
Last Post: zer0sig
  PinePhone BE & Pinebook Pro shipping update thread Luke 136 289,220 06-04-2021, 09:43 AM
Last Post: Luke
  PinePhone Mobian CE shipping update thread Luke 59 147,389 04-25-2021, 12:57 PM
Last Post: Luke
  PinePhone BETA Edition pre-orders start March 24 Luke 2 13,621 04-23-2021, 09:25 PM
Last Post: ryo
  PinePhone KDE Community Edition shipping update thread. Luke 135 305,257 04-11-2021, 01:47 PM
Last Post: Luke
  Manjaro PinePhone Community Edition Luke 17 49,378 11-02-2020, 01:32 PM
Last Post: bcnaz
